 250WB A/C size
e714753
Initially Posted - 03/17/2016 :  18:11:44  Show Profile
I have a spring project to install an A/C unit in my 2012 250WB. I was planning to install it in my V-birth storage space forward of the potable water tank. I have extensive knowledge of A/C installations in the commercial market but need help in the size unit to use in this marine application. I live on the Chesapeake bay in Virginia and wanted to know if a 5000 btu unit is large enough for this boat. I am aware of the calculation that can be used to determine unit sizing but I am more interested in proven unit sizes already installed. What size units do you guys have?
Thanks in advance!
Russ.Johnson
Commodore
Response Posted - 03/17/2016 :  20:49:09  Show Profile
Robert,
I don't have A/C on my boat, but there are other posts about them.
Also, our Photo Gallery (left menu) has a Projects section where an A/C project was posted.
https://www.catalina-capri-25s.net/cgi-local/MBR_gallery.cgi?Album+1000+76
You can also use the Forum Search feature (top of the page).
There is a large archive section, so verify that box is checked.
Here is an example found using Search.
http://www.catalina-capri-25s.org/forum/topic.asp?ARCHIVE=true&TOPIC_ID=26022
Russ Johnson
2005 C250WB Hull 793
Response Posted - 03/24/2016 :  08:12:44  Show Profile
Contact BritinUSA through the forum. He did this in Florida.
1999 C250 SR/WK #410
Bay Village, Ohio
Sailing Lake Erie
Don't Postpone Joy!
