I'm pretty sure that my fresh water tank is leaking. I think it is a 14 gallon tank, blue poli under the starboard settee. Does anyone know how to get this tank out for inspection, repair or replacement without cutting up the settee ? Thanks, looking forward to your comments.
Well for your fist question you came up with a doozy... I've often looked at the water tank and wondered if it was possible to get it out in one piece without cutting the fiberglass two top pieces that the wood hatches fit into. Hopefully someone here has gotten it out without to much destruction because I sure would like to know also. Seems to me that Catalina built the whole boat around the water tank.
I wouldn't cut up the boat... I'd cut up the tank, toss it, and install a flexible one in its place. Check out the Plastimos in WM--simpler maintenance, and less air to support evaporation of chlorine and growth of other stuff.
I was able to pull my tank out without cutting anything. I just had to lift the wooden seat. Is your settee different from mine? I have an 87' with the traditional interior.
Good idea if I were certain it is leaking. I will have to test to be sure. I will check WM for the bladder tanks. Seth, My C25 is neither a traditional nor a dinette. It is an "L" shaped Dining area. However, my starboard settee should be the same as everyone elses. Except that the tank will not come out thru the settee storage boards. Nor from either end. Wish it were that easy. Thanks.
Good question, I wondered the same as well. Do you have a wooden vertical support just forward of the tank? I would surmise if you can remove that, then you could rotate/move the tank enough to pull it out. Good Luck, and take pictures.
As for replacement, one that fits in easier may reduce tankage a little, but would be easier to install. I would prefer a rigid versus bladder tank personally.
s/v No Worries, O'Day 28 PO Moe'Uhane - C25 SR/FK #1746
My tank also came rite out. Later i moved the bulkhead and turned the space into storage. I installed a rectangular tank in the bow and so far we really very pleased.
quote: Are there differences in the seats between years?
After reading these replies I'm starting to think so. To make sure we are on the same page we are talking about the fresh water tank under the starboard settee right?
I have a partition immediately forward of the tank and immediately aft of it. yes, it is the fresh water tank under the starboard settee.Thanks for all of the responses and ideas.
You have to remove the wood partition to get the tank out. That's what I did. Yours is leaking so your tank should be empty. I disconnected the output hose before checking to see if the tank was empty!!!
Yours is different than mine was. In my 84 boat, the space under your blue bucket was the battery compartment. The water tank was more forward next to the main bulkhead. And the tank was white plastic, not blue. Looks like you will have to remove the aft partition in order to remove the tank.
DavidP 1975 C-22 SK #5459 "Shadowfax" Fleet 52 PO of 1984 C-25 SK/TR #4142 "Recess" Percy Priest Yacht Club, Hamilton Creek Marina, Nashville, TN
quote: the space under your blue bucket was the battery compartment.
There are some differences, My Battery compartment is in the area aft of the aft wood partition, I also have a white poly tank but my tank runs the full length from the aft partition up to the main bulkhead or close to it. The fitting for where the water is drawn out of the tank extends through a hole in my aft wood partition into my battery compartment. You can see in this photo how the fitting comes through the partition and the hose connected to it then to the water pump.
I don't have any pictures handy but I have a '77 C25 and it looks identical to Islanders '87, white poly tank with the outlet coming through the wood partition into the battery compartment so I don't think anyone can go by just the year of the boat. Maybe it depended on the day of the week.
My batteries are behind the ladder in a molded compartment.
My tank is half the width of the starboard settee under a wooden platform that screws into the bench. So when you take it off, there is tons of room to remove the tank. It's not the smaller panel like the other compartments.
1989 C-25 TR/WK #5894 Miss Behavin' Sittin' in LCYC on Canyon Lake, Texas
I thought my water tank was just a wee bit too big to come out but then I noticed the filler hose, the air release hose and the head sink hose were routed next to the outer side of the forward end of tank. When I pushed them all out of the way, there was just enough room to move the forward end of the tank up out of the settee. I wedged it little by little, then removed the hose clamps and freed the aft end. lo! The tank was freed! I pulled it out and opened the inspection port and was able to get a long handled brush inside to clean out the green, grey and brown gunk. I swished it out with full strength Clorox, then white vinegar, then dish soap and finally rinsed it with clear water. I took out several hoses and did the same to them, but pushed a coat hanger wire thru with a wad of bleach soaked rag on the end. After finally putting it all back together, I filled the tank with a gallon of water and bleach and pumped it thru the sink pump handles and emptied the tank. I finally put about 5 gallons of water with a cup of bleach in and I have been using the water to wash hands for awhile. So far so good. The water's stayed ok - it hasn't gotten funky yet. Getting the tank out of my dinette style interior was tricky and took a lot of finagling but it was possible. I just got lucky I guess.
As we are finding out, Catalina didn't use the same tanks through the years. This is good to know if and when a question about the tanks comes up again. By the way this is my tank in an 87 soooo You can see my bewilderment when others have said that it simply lifts out. Looks and is shaped totally different than the photo above.
quote:the settee is on Passage is constructed quite differently.
I don't know how that could be. The settee is part of the liner and mine is the same as Bladeswells 79. As far as I can tell the settees are all the same through the model years except maybe the last 2yrs. The difference is the tank size/configurations and partitions inside the settee frame.
It looks to me as well that the settes are all the same, but that the partitions are just located differently. I was guessing my tank size at 14 gallons, but according to Catalina it is 16 gallons. Thanks again for all of your help. I believe the best bet for removal will be to remove the aft partition and reinstall it in such a way as to make it easily removed in the future. After I determine if my tank is where the water is coming from. Again, my thanks.
