 SOLD - We're Selling JD our Catalina 250 WB
Initially Posted - 05/10/2015 :  16:04:53  Show Profile  Visit britinusa's Homepage
---- SOLD ----
The new owners of JD have just left for their journey back to the Melbourne Florida area.
He has already been lurking around here, I hope that he joins the Association and gets as much from it as I still do.
There's a lot more space in our Garage! Boat Cushions, Sail Bags, Generator, etc. etc.
If we didn't have our C34, this would be a sad day, but knowing that the boat is going to a guy that loves sailing and is moving his family to share that affection is a great result of selling JD.
--------- SOLD ----------------
Yes, it's time.
I'm retiring in November 2015 and we want to sail further than we can go on our Catalina 250.
We are purchasing a Catalina 34 and have to sell JD.
JD is a great boat that will give the new owner some great adventures. Even in South Florida, with the Installed Air Conditioning and onboard Generator, cool evenings in new locations are a great way to get away from it all. Trail the boat across the State, Up or Down the coast, there are so many places to launch the boat and enjoy sailing.
Here's the specs,
CATALINA 250 WATER BALLAST FOR SALE 2005 LOADED. WITH TRAILER ASKING $18,500
PRICE: $18,900
CATALINA 250 (WATER BALLLAST)
YEAR OF MANUFACTURE: 2005
Contact PAUL ALCOCK, BRITINUSAG1 at GMAIL dot COM
TELEPHONE #:954-736-7114
2005 CATALINA 250 WATER BALLAST LOADED.STANDARD FEATURES PLUS
Sails:
- 110% Furling GIB. Good
- 150 Furling GIB Fair
- 2 REEF MAIN Good
- Riding Sail (Sailright Patterned)
- Asymetrical Spinnaker - Fair - Chute Good, home made Tack Collar on Furled Jib stay
Deck:
- 2 Lewmar Single Speed Self tailing Winches on Cabin Top
- 2 Double Line Organizers located Port & Stbd Cabin Top
- Twin Line Stoppers(total of 4) on each side of Cabin Top (Main Halyard, Vang, Reef Downhaul, Reef Outhaul)
- Furling line cleat Port side
- Spinnaker Tack Block on Pulpit, then aft to Port Side Winch
- Spinnaker Sheet Blocks on Port & Stbd Catbird Seat Rails then to captured cam cleats on combings.
- Bow & Stern Nav Lights
- Mast Steaming Light and Deck Light (new 2015)
- Single Lifelines with Pelican hooks each side of cabin for easy opening.
Spars & Rigging:
- Standard Mast & Boom
- Boom Kicker & Vang
- In Boom Main outhaul & Topping lift
- Additional cleats on Mast (port & stbd)
- Lazy Jacks
- Flag Halyards Port & Stbd on the Spreaders
- Mast Raising Strap
- Stainless Steel stern Mast Support (removable) on dedicated pintals
Keel:
- Water Ballast Tank
- Swing Keel with modified lifting tackle
Running Rigging:
- Jib Sheets with track and cars inline with Shrouds
- Main sheet in Cockpit
- Spinnaker Sheets
- Spinnaker Tack line
Cockpit:
- Wheel Steering (Includes Arlyn's Wire Steering Upgrade)
- Stainless Pedestal Guard
- Ritchie Compass on Binacle
- Catbird Seats
- Outboard fuel tank locker aft of helm
- Manual Bilge Pump (port side)
- Stainless swing down swim ladder
- Inclinometer on stbd side cabin aft bulkhead.
- Extra Stainless Steel Handhold by Swim Ladder
- White Vinyl covered cushions (5) Port & Stbd cockpit seats, Port & Stbd Cat bird Seats, Fuel locker top
Electrical
- 12v Distribution Panel with Circuit Breaker(standard)
- Garmin 562 GPS Chart plotter built in antenna
- VHF with Masthead Antenna with DSC & GPS interconnect & MMSI (transferrable via Boat US)
- Raymarine ST40 Wind display system - Display on Cabin outside bulkhead, Transducer at Mast head.
- Raymarine ST40 Depth/Speed/Water Temp Display at helm (Speed Transducer replaced new April 2015)
- Subaru 1700 Watt Generator (sits on Fuel Locker under sail, by swim ladder at anchor when needed)
- Marine Cabin Stereo in Cabin with Stereo speakers beneath Cabin table.
- 400Watt Invertor (Stbd Side forward of galley)
- Dual USB outlets (Stbd Side forward of galley)
- 2 - 12V DC outlet (Stbd Side forward of galley & below Power Distribution Panel)
- Dual Battery 110V smart charger
- 110V Shore power connector (Stbd side below Catbird seat)
- 110V Shore power pigtail (boat to Generator)
- 110V Shore power cable (boat to shore)
- 110V Blue Sea Main Breaker Switch (aft head bulkhead)
- 110V Sub Switch panel (aft head bulkhead - 3rd switch is spare)
- 110V CFGI Power outlet beneath Battery Charger on Quarter Berth Aft Bulkhead.
- 2 x 75 AH Wet Cell Batteries in Trunk behind Aft Berth
- Batteries have remote cell water top up system installed (top up without removing batteries)
- Cabin lights (Most lights have been swapped out with LED's)
- 19in Flat Screen TV on Swivel Mount(2014) on Forward face of Head Bulkhead, with Remote
- Pole mounted Unidirectional TV Antenna(2015) on port side catbird seat.
- 50W Solar Panel Stbd Side Catbird seat on directional swivel can point 360 horizontal, 135 vertical
- 15Amp Solar Panel Control Unit
- Off/1/Both/2 Battery control switch inside Stbd Cockpit Locker
- INSTALLED CABIN AIR CONDITIONING. (on shelf aft of head in quarterberth)
- 12V power wash pump below Galley cupboard - shower hose connection port side gunwhale.
- 110V/12V Dometic Cooler style Fridge Freezer Stbd Side aft of Galley
- 12V LP Air pump (Empty Ballast while on the water)
Galley:
- Single Burner Butane Cooker top with piezo start & flame protect
- Stainless Sink with manual whale pump faucet.
- Cup and Plate rack built into back of Gallery counter
- Cutlery Draw beneath Cooker top with spring restrainer.
- Didi Draw aft end of Cooker top below counter
- Galley cupboard below Sink with two shelves inside
- Galley storage area beneath cutlery draw (can hold additional cooler if required)
Engine:
- Electric Start 2007 NISSAN 9.8HP OUTBOARD.
- Detachable Hard Link to Rudder
Cabin:
- Custom drop leaf table - lowers to extend V-Berth
- Blue Catalina Cushions on V-Berth, Port & Stbd Settee, and Settee Backrests(3)
- 3 Steps ladder from Cockpit
- Water Ballast valve access under lower step of ladder
- Pop-Top support bar mounting below Companion way
- Pop-Top Curtains for privacy/sunshade when needed
- Magazine Rack on port side behind TV
- Companionway shutter mounted on raised supports port side of ladder
- 5Gallon Porta-Potti head
- Built in sink in Head
- Whale water fawcet in head
- Hanging storage locker aft head bulkhead
- V-Berth storage cover has Hinged mod to allow easier access
- Port & Stbd Settees with Storage below
- Aft Berth
Tanks:
- 17Gallon Solid Plastic water tank below aft end of V-Berth
- 26Gallon Flexi water tank below V-Berth
- 3.5Gallon Solid Plastic Fuel tank in fuel locker in Cockpit
Canvas:
- Blue Sunbrella Bimini on Stainless tubing (2013)
- Black mesh Sunshade zips into aft end of Bimini (2013)
- Blue Sunbrella Boom Tent (2013) zips into fwd end of Bimini covers Pop Top
- Original Pop Top Cover with clear windows and bug screens
- Line bags on Port and Stbd aft Cabin Bulkheads below winches
- Blue Sunbrella Binnacle Cover (covers GPS, Pod & Compass)
- Blue Sunbrella winch covers (2)
Trailer:
- Sail-king Trailer
- New Axles 2013
- New Disc Brakes (all wheels) 2013
- New Suspension (2013)
- Most lights replaced with LEDs
- Trailer to Truck 7 pin round connector
- Breakaway restraints & Surge break connectors
- High Trailer guides posts
- Mast Raising Post on Trailer Tongue
- Mast raising post ladder
- Extra Length Trailer Extension tube (slides below fixed trailer tongue)
We have used JD (Joint Decision) to sail locally in Biscayne Bay mostly on 3 to 5 day adventures, also sailed her to Bimini (52miles), Outside down to the keys and inside back to Biscayne Bay on a 10 day cruise.
Our tow vehicle is a Ford F150 Super Cab which manages towing without any issues. (Truck not included but make me an offer :)
We have trailed JD to Pensacola for a 5 day cruise, to Cocoa Beach for a 4 day cruise. But most of our sailing has been in Biscayne Bay launching from Black Point Marina.
Launching JD is easy, takes a while to get her rigged. I'm 66 and in good shape, so I have no problems getting the boat prepped for launch or retrieving the boat for the tow home.
I'm retiring in November 2015 and we want to go cruising to the Islands an up to Maine, we need a bigger boat.
If you are interested in buying a great boat, that is rigged to allow you to enjoy multi day trips, then contact me.
Email: brit in usa g1 at gmail dot com
Or call my cell phone Nine Five Four hypen Seven Three Six hypen Seven One One Four
Joint Decision. (Sold)
PO C250WB 2005 Sail # 841.
Moved up to C34 Eximius
Updated August 2015
Edited by - britinusa on 08/14/2015 15:37:16
Response Posted - 05/10/2015 :  16:36:21  Show Profile
Are you sure that a C34 will fit next to your house........?
It's been about a year ago that I purchased the Gemini and sold my C25. Miss it every now and then, but love all of the space on the catamaran.
Good luck with the sale and good luck with sailing to farther destinations.
2005 Gemini 105Mc
PO 1987 C25 #5509 SR/SK
Tampa Bay
Response Posted - 05/10/2015 :  18:58:43  Show Profile  Visit britinusa's Homepage
Thanks Davy,
The C34 we're hoping passes survey, is special! The owner has done a lot of mods on the boat to make it as close to a blue water boat as a c34 can be.
I know what you mean about the C25/C250, we have had some great fun on the boat, and as it is kitted out for multi-day/night cruises, we have become very used to how she sails and hangs off the hook. We had intended to take her out for the Memorial day weekend despite the lack of takers for the trip on the Florida West coast, we were going to spend the Friday thru Monday sailing about the lower end of Biscayne Bay and Card Sound. Not sure we'll be able to do that in the C34. JD has been really well suited to sailing in our area, and there are so many places along the Florida coast to enjoy.
Someone is going to get a boat ready to launch and sail!
Updated August 2015
Tomas Kruska
Czech Republic
Response Posted - 05/11/2015 :  07:32:33  Show Profile  Visit Tomas Kruska's Homepage
Good luck selling your very nice boat and good luck sailing the distances!
Dalpol Phobos 21, 2013, Sole Mio, hull #27, current adventures - We sail Phobos 21
PO of Catalina C25, 1978, High Anxiety, hull #701, SR, FK, L-dinette, inboard diesel Volvo Penta MD2010C w/saildrive - more info
BCG-Woodbury
Mainsheet Editor
Response Posted - 05/12/2015 :  10:21:39  Show Profile
Paul -
Sounds like a great plan. Are you planning on taking any additional ASA classes in Key West? Maybe Brad would be interested in your bout for his school?
Best of luck,
Brian & JoAnne Gleissner
Knot So Fast
1984 Catalina 25, SR/SK
Traditional Interior
Lake Candlewood, CT
Response Posted - 05/12/2015 :  11:00:17  Show Profile
Hmmmmmm... Big problem! Big trouble! Very worried!!
Response Posted - 05/12/2015 :  13:12:43  Show Profile
Dave, I agree if your thinking what I'm thinking..
Response Posted - 05/12/2015 :  13:26:53  Show Profile  Visit britinusa's Homepage
No need to panic guys.
I'm already working on more stuff for the Association
Unless you think the C34 is a big problem
Paul.
Updated August 2015
BCG-Woodbury
Mainsheet Editor
Response Posted - 05/13/2015 :  14:38:17  Show Profile
Hey Paul -
Do you think you could could whip up a destination article for the next issue? I'm sure the readers would love to hear about the trips you've made with JD. You have a month or so, let me know if you are interested.
Knot So Fast
Lake Candlewood, CT
Response Posted - 05/14/2015 :  11:02:39  Show Profile  Visit britinusa's Homepage
Sounds like an idea Brian (both of them)
Peggy & I have talked about doing the next ASA course, we have the book and are working through it.
I'll knock out a blurb about our trips with JD, but it will not compare to those from Henk.
Updated August 2015
BCG-Woodbury
Mainsheet Editor
Response Posted - 05/14/2015 :  17:00:12  Show Profile
All articles are welcomed. Keep them coming. I'll be posting a request for more articles shortly. Either way, you can still contribute to the C25/C250/Capri 25 Group, I won't tell. LOL Best of luck with the new boat and the ASA courses. I'm hoping to do 103 this November when I'm down for Thanksgiving. I'll look you up then.
Regards,
Knot So Fast
Lake Candlewood, CT
Response Posted - 06/22/2015 :  05:16:30  Show Profile  Visit britinusa's Homepage
Brian, let me know when you'll be down here.
JD is sitting silently on her trailer, but still being cared for. I'm taking the tarp off this week so that the broker can stop by and take pics. While she is uncovered, I'm going to replace the deck/steaming light fixture, the old one looks old. I want the buyer (when JD finds them) to be able to take the boat to a launch site and go sailing and not have to worry 'do the lights work' Of course they do!
We had the renaming ceremony of our new boat this weekend, was a blast.
Updated August 2015
Response Posted - 08/15/2015 :  07:23:03  Show Profile
Congrats! Enjoy the BIG boat!
Tom Potter
Response Posted - 08/21/2015 :  19:17:38  Show Profile
Paul,
Congratulations! If you're cruising the ICW through North Carolina and need a place to stop and stretch your legs, we have room at our dock. We're just a few miles off the ICW up the Pamlico River.
1997 250 TR WK (sold)
1984 O'Day 28 (sold)
1979 SISU 22
Bath, NC.
Response Posted - 08/22/2015 :  07:39:09  Show Profile
...then up the ICW to the Chesapeake, the C&D Canal, NY Harbor, through Hell Gate into Long Island Sound, up to Mystic, Block Island, Menemsha, Vineyard Haven,.....
glivs
Response Posted - 08/23/2015 :  12:39:42  Show Profile
... And then up the Hudson to Whitehall and on into Lake Champlain...enjoy the sights and then continue to the St Lawrence and then west to the Great Lakes...
Congrats Paul & Peggy, many great adventures ahead...
