 Flag Halyard
Initially Posted - 04/20/2015 :  05:00:41  Show Profile
<< Rob is wearing me out! >>
He's about to kill me...
Yepper.. He has reminded me of another maintenance thing I need to do.
Drop the mast, Inspect and/or replace the spreader wire, add a flag halyard, and repair/replace the wind vane.
Raise the mast and re-tune the rig.
Any special instructions on a Flag Halyard? Inside, outside, middle of spreader?
I imagine I'll use the same tap and screws I used on the mast gate and add a strap holding a block.
I think I will double wrap the wire at the spreader ends to hold the spreader up in place.
Response Posted - 04/20/2015 :  06:02:47  Show Profile
Middle..Less chance of the flag slapping the shrouds or mast
The seizing wire doesn't support the spreader, Just keeps the shroud in the end cap slot. Its not wrapped tight around the shroud but is a loose loop so the shroud can slide through it. A good trick is to take a toothpick placed alongside of the shroud then wrap the seizing wire around the shroud and toothpick forming the loop. When you finish remove the toothpick and now the loop is just loose enough to allow the shroud to slide through it.
wanderer13
Response Posted - 04/20/2015 :  09:35:45  Show Profile
Don't waste your $$$ on a flag halyard "kit". You can build your own with an eye loop, mini-block, nylon messenger line, and a small cleat on the mast (a little higher than your whisker pole ring). I put the pulley/block about 1/2 - 2/3 outboard on the spreader. I put mine in for <$10 with almost new equipment I found at a marine consignment shop.
Response Posted - 04/20/2015 :  09:56:51  Show Profile
<< Its not wrapped tight >>
Did not know that.. I've always worried the flag halyard would pull down on the spreader. Oh. and I didn't know the rig could come down if the stay jumped the spreader, so I guess that little wire is kinda important..
Can I use the stainless wire they sell for securing the anchor rode shackle?
I was thinking about putting the block just inside the stay, and use a cleat mounted stay below it. Or even just mount the block on the stay, just to keep everything away from my external halyard on the mast.
Edited by - redeye on 04/20/2015 10:12:09
Response Posted - 04/20/2015 :  10:18:35  Show Profile
Ray, why are you going to the bother of dropping the mast just to do that. It can all be safely done from a bosun's chair (I've got one I'll sell for $50).
Chief Measurer C25-250 2008
San Antonio, Texas
Response Posted - 04/20/2015 :  10:33:28  Show Profile
I don't know if it's the same or not but this is what I used from CD
http://www.catalinadirect.com/index.cfm/product/1931_149/seizing-wire-stainless-steel.cfm
Response Posted - 04/20/2015 :  10:57:16  Show Profile
Yep.. thats it.
Response Posted - 04/20/2015 :  10:59:07  Show Profile
<< It can all be safely done from a bosun's chair (I've got one I'll sell for $50). >>
Got a climbing harness...but I've got a stress fracture in my foot right now so I've gotta behave till it mends...
Doing a lotta mootoring with my new 4HP trying to get 10 hours in at 1/2 speed as a breakin procedure
Edited by - redeye on 04/20/2015 11:11:40
dasreboot
Response Posted - 04/20/2015 :  11:10:48  Show Profile  Visit dasreboot's Homepage
i read a good rule of thumb for going up the mast on small boats. ballast should be 10 times your body weight. that lets me out. I've only ever gone up on a 36 foot boat with 9000 pounds of ballast.
Todd Lewis
Eowyn 87 TR/WK C25 #5656
ARWEN 84 TR/SK C25 #4031
www.mainsailsailingschool.com
Response Posted - 04/21/2015 :  20:40:25  Show Profile
Todd, my foredeck guy once spent 30 minutes at the masthead changing out the halyard sheaves - and he weighed 185lbs so that 10x may not be accurate.
San Antonio, Texas
Response Posted - 04/22/2015 :  07:56:49  Show Profile
You had 1900 lbs of ballast--no prob!
