Hi all Checking the 'new' boat out I found that the hull valve under the fwd berth is stuck. The marina owner suggested Marvel Mystery oil to free it. Sound ok? Also, this hull valve has a "T" on the inboard end. It acts as the drain for the sink in the head on one side and the other goes to the Jabsco head intake. I looked at the manual and it shows an intake hull valve port side just aft of the head. It would seem to me that when I try to flush, it will try to suck air from the sink? Or, since the hull valve is below the waterline, will it suck water? Any thoughts on either of these? Thanks in advance for any help. Jay
Jay South County RI Cat 25 SR/FK/Trad #5645 Wind Dancer
Your suspicion on the "T" is correct. But a simple rubber stopper for the sink will solve it.
If the valve is stuck in the closed position, I'd start with a shot with a pressure washer from the outside, hopefully to loosen scale that's stuck to the ball in the valve. If that doesn't do it, I might try something like a bathroom tile cleaner or something with oxalic acid applied from the outside. The scale has to be removed--I don't think lubrication is the answer at this point--although some lubrication and periodic opening and closing (at least monthly) will help prevent this in the future.
Be careful if you use a pressure washer - Use minimal spray at first and see how that works.
I keep my boat in the water, year-round (Potomac River), and have the bottom annually pressure washed to remove the slime build-up. In the past, I have had no problems when they pressure washed the hull, gave a shot at the flowmeter transducer to unclog it and same with the seacocks. On the seacocks, after they pressure washed, I then shoved some silicone grease onto the ball using a small brush. Then when back onboard, I would cycle the seacocks and they have remained smooth in cycling.
However, last year, when my flowmeter transducer was clogged and they pressure washed it to remove the slime. It still was a bit sluggish and so they gave it successive shots with the pressure washer. The flowmeter transducer broke off and took with it a piece of the housing from within. Luckily, it was the inner housing that was part of the transducer drop-in and not the pressure housing. I have the replacement transducer and inner housing from SR Mariner and will replace it some time this spring/summer.
Okay - You are dealing with a valve and may not have same concerns that I experienced with the flowmeter transducer but the pressure washer can subject the component to significant pressures if you do not lower the pressure washer spray setting.
There is a product that is designed to remove sea crust if that is your issue with the valve. It is called "Salt Away". You just have to read if there are any matl restrictions to it to ensure it is compatible with your valve, etc. That may be worth a try.
Bar Keeper's Friend spray cleaner, Armor All Wheel Cleaner,... Somebody probably has a "marine quality" version for triple the prices.
The Maine grade I believe would be Hull Cleaner. Wood bleach/Teak brightener also contains it. These probably at 4-5% concentration. Or you can buy it in a crystal form at 99% concentration and have enough to make your own Hull cleaner for a lifetime. Just mix a tablespoon into water.http://www.amazon.com/Oxalic-Acid-99-bag-C2H2O4/dp/B007HUR0EK
I'll suggest if your seacock is bronze, don't leave the cleaner in there very long--give it let's say 10 minutes, flush it out with a strong spray, and then try the lever. Repeat as necessary. If it's plastic, you can let the cleaner work longer.
Jay Glad the "treatment" took care of your valves. As Dave mentioned there might have been some marine growth buildup in the valve opening. I had a similar situation with the head sink valve in the vee-berth. It was on my spring commissioning to-do list. In my case I looked up inside from under the boat - clean! I sprayed some WD-40 and silicone up, then went inside the boat and removed the hose and hose barb fitting and shot some oil down the hole. After some struggling and a few choice words, the valve moved and I was eventually able to work it free. Now that's on my monthly checklist of things to do. But one last issue bugged me - did any rubber O-rings or seals crack when I loosened it? I did not want to launch, THEN find a leak... So I closed the valve, reassembled the hoses and filled the sink with water. Glad to report she held for the entire week, so no leaks!
