 Jib cam cleats
vipermagic
Initially Posted - 03/21/2015 :  17:43:33  Show Profile
Happy Spring, everyone!
I have a set of cam cleats to put by my foresail winches, and was hoping for a little guidance as to where to put them. My old boat had them where the current boat has horn cleats, but I'd like to leave the horns also, as backups and for heavy weather.
Also, do I need a set of risers for the cams?
Any suggestions?
Thanks!!
79 C25 #1433 SR/FK - 'Carina' - Destroyed by Sandy
84 C25 #3817 TR/SK
Cleveland, OH
Response Posted - 03/21/2015 :  19:30:13  Show Profile
Put them in line with the outside edge of the winch on starboard and the inside edge on port so that the jib sheets comes straight back into the jaws. Risers are a great idea as they help prevent overrides.
You do not need the horn cleats - donate them to Poseidon.
Chief Measurer C25-250 2008
San Antonio, Texas
hewebb
Response Posted - 03/22/2015 :  06:07:09  Show Profile
I placed mine where Derek mentioned except on the starboard side I could not get to the screws so had to move it a small amount. Originally I made a 1" teak block for a riser but the sheet would pull out and was hard to set. I added an additional 1/4" and now they work well. I looked but did not find any photos of the installation.
Hobie 18 Lake Worth
Response Posted - 03/22/2015 :  06:48:55  Show Profile
use an angled riser. had them on my C25, and they were the best setup I have yet encountered...
s/v No Worries, O'Day 28
PO Moe'Uhane - C25 SR/FK #1746
Response Posted - 03/22/2015 :  10:13:45  Show Profile
I positioned my cams so that after trimming with the winch, I could hook the sheet under one horn of the horn cleat and snap it into the cam cleat--no riser needed that way.
ct95949
Aruba
Response Posted - 03/22/2015 :  10:53:22  Show Profile
In this pic I have my furling line and jib sheet in the wrong cleats (one of my newbie mistakes). After I switched the lines and used them awhile I realized I could have put the cam where the horn cleat is, I almost never used the old cleat. The risers helped a lot allowing for downward pull. I would sail the boat and mark the angle coming off the winch using your normal positions while single handing, heavy wind, etc.
'90 SR/WK #6017. PO of '79 SR/SK.
