 Fresh Water System PO Fun, and What Faucet
sethp001
Mainsheet C-25 Tech Editor
Initially Posted - 07/12/2014 :  20:25:40  Show Profile
Hey everyone,
Funny thing, my boat came with pressurized water. The PO gutted the existing Whale flipper faucets and threw a bilge pump in the water tank. When you flipped the switch, both faucets ran.
Other fun occurred the first time I tried to fill the water tank through the deck fitting when my wife said, "Is there supposed to be water coming up from the floor?" The inlet pipe wasn't connected to the water tank!
So I've ripped out all the plumbing which looked pretty cruddy and intend to install new. I've been searching forum all night but can't seem to find an answer to this question:
When going to pressurized cold water only (intended use pump, not bilge), what's a good faucet replacement for the Whale flipper faucets, thinking of something that will fit in and cover the hole (approx 2") in the counter into which the Whale faucets fit?
jduck00
Response Posted - 07/13/2014 :  06:20:13  Show Profile
I used one similar to this one:
http://www.homedepot.com/p/Watts-1-Handle-Designer-Non-Air-Gap-Faucet-in-Brushed-Nickel-for-Reverse-Osmosis-System-0958241/203208983
Had to gently bend it to fit the boat. I don't know if it will cover a 2" hole. That might be a challenge.
Response Posted - 07/13/2014 :  07:13:51  Show Profile  Visit britinusa's Homepage
could you use one of [url="http://www.grainger.com/product/Flat-Washer-29DU04?functionCode=P2IDP2PCP"]these[/url] to cover the hole under the new faucet?
Response Posted - 07/13/2014 :  07:53:18  Show Profile
I think you will be hard pressed to find a faucet that will cover the hole. I simply made cover plates from an inexpensive 1/4" plastic cutting board, Screwed them down and cut a new hole for the new faucets. The galley sink is a standard pull out faucet sprayer from any HD or the like. The faucet in the head I got from EBay.
Akenumber
Response Posted - 07/13/2014 :  14:32:25  Show Profile
RV and trailers usually have pressurized plumbing. Lots of online options.
Response Posted - 07/13/2014 :  15:36:08  Show Profile
RO systems have faucets cheap as well
.our boat uses those with 1/4" nylon tubing
upnorth-mn
Response Posted - 07/27/2015 :  09:15:04  Show Profile  Visit upnorth-mn's Homepage
Has anyone ever modified the insides of the Whale Pump to work with an electric pump inline?
Up North - C25 SR/SK Traditional w/Pop-top #2172 / Lake Pepin
upnorth-mn@nym.hush.com
she's an old boat he says / with gate valves as seacocks / cracked and weathered teak / and sails misshapen / from close hauled tacks upwind
NautiC25
Response Posted - 07/27/2015 :  10:36:10  Show Profile
I bought a nice bronze faucet from Lowes that more than covered the hole. Then added an inline 12v RV pump to feed it. A master switch turns it on to prime it to a certain pressure. Opening/closing the faucet activates/deactivates the pump.
1989 C-25 TR/WK #5894
Miss Behavin'
Sittin' in LCYC on Canyon Lake, Texas
Stu Jackson C34
Response Posted - 07/27/2015 :  18:45:03  Show Profile
Whatever faucet you get, I strongly suggest you get one with a single handle that does both volume and temperature, if you ever think of hot & cold.
On our C34 our galley sink has individual knobs for hot & cold, and it's a PITA. I got a water saver doohickey for the spout so I just press a button to turn it on & off once the temperature is set.
Double handles may work well at home, but they actually use more water, too - run until you get the mix right wastes water, repcious on a boat.
Stu
1986 C34 #224 "Aquavite"
Cowichan Bay, BC Maple Bay Marina
(formerly San Francisco)
(formerly C25 #2459 "Capricorn Two")
Edited by - Stu Jackson C34 on 07/27/2015 18:45:57
sethp001
Response Posted - 07/28/2015 :  08:09:43  Show Profile
That's actually what my PO did - ripped out the guts of the Whale flipper faucets.
Seth
"Nomad" 1980 Prindle 16
Response Posted - 07/28/2015 :  15:24:06  Show Profile
If you want an on-demand system (that turns off the pump when you turn off the faucet, due to back-pressure), I think you need a standard faucet with single or dual valves. I don't see how a "gutted" whale could do it. Get a cheap, simple faucet from Home Dopey, or something fancier if you like, and an on-demand pump from WM or wherever. Then cap off the hot supply line on the faucet so water doesn't escape through it.
ct95949
Aruba
Response Posted - 07/28/2015 :  19:40:42  Show Profile
I wanted a single handle. I think I got this on Amazon for about $40 and had to add a washer for the big hole. The pump I had left over from my old boat, added a strainer, everything was really easy to
install. I plumbed the supply to both the hot and cold lines with a tee, works great. Some upgrades end up being a waste of time and money- not this one.
'90 SR/WK #6017. PO of '79 SR/SK.
Response Posted - 07/28/2015 :  20:10:53  Show Profile
Yup--a T to both sides of a single-control faucet makes it work the same regardless of where the handle is left-to-right. Mine is a two-control faucet--just the cold handle works. But it's on-demand pressure, which is very nice.
hewebb
Response Posted - 07/30/2015 :  03:58:00  Show Profile
I installed a pressure system using an RV demand pump and this faucet from Defender.
Hobie 18 Lake Worth
