I'm replacing a depth finder on a C-25. The old instrument is probably an original and occupies a 6 inch hole on the port side of the companionway opening. The new instrument is only about 2 inches wide or so.
Any thoughts on how to install the new instrument into the old opening and make it look decent?
Also, what is the best place to install the transducer inside the hull?
I'm doing the same thing this winter. I was going to mount a teak or starboard plate over the old hole and put the new instrument on that. My new instrument comes from nasa marine. They say to mount the transducer directly to the hull using epoxy. I was going to mount it forward under the vbearth to avoid bubbles around the keel.
Take the original housing from the depth finder and gut it. If the face is glass, replace it with Lexan. Spray paint the back (inside) of the Lexan to match the color of the housing, use proper paint rated for plastic. You can now mount the new instrument in the old existing housing
Deck plates/ Access ports are a viable go to solution to a lot of things. If you are not familiar with them they come in several colors, sizes, and closing types; I prefer screw in over snap in myself. Also Hobie makes them that have little storage bags that drop into the ring which are kinda cool. You could easily have two covers, one with your readout and one plain one and splice a plug into the wiring just behind the cover, that way you could put the plain cover in place and put your readout away when you are not sailing. I hope you are enjoying the forum, when I first logged on I read about a year's worth of posts and it was very helpful to me as a new C 25 owner.
Thanks for all of the advice. It's great to be part of the club now.
I did look at deck plates over the weekend. While I might be able to fit one I would then have the problem of trying to cut a 2 inch hole in the middle. Instead, though, I got contact information for a place that I'm told does custom cuts in starboard. I'm going to try and get a plate cut slightly larger than the existing hole and have them cut a hole in the middle for the new depth finder.
I used waterproof adhesive caulk to "glue" the transducer to the floor in the v-birth. It works pretty good, though now and then it loses the return pulse and has to search for a few seconds before it again receives the return signal.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by eyeager66</i> <br />Thanks for all of the advice. It's great to be part of the club now.
I did look at deck plates over the weekend. While I might be able to fit one I would then have the problem of trying to cut a 2 inch hole in the middle. Instead, though, I got contact information for a place that I'm told does custom cuts in starboard. I'm going to try and get a plate cut slightly larger than the existing hole and have them cut a hole in the middle for the new depth finder. <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
You mean you are not going to a surface mount fish finder!!!!!! They are so must less expensive, can come with gps and work so well that most have walked away from the old sailboat depth sounder units.
