[NOTE- how do I move this to the "general sailing" section?...]
There have been a number of threads recently regarding wood treatment. I don't recall reading any suggestions regarding integrating epoxy but forgive me if it was already covered...
Our hatch boards and cubby rings were fine sanded, wiped with mild solvent to clean, then coated in two layers of West Systems 105/207 (clear hardener). We fine sanded and cleaned between coats of epoxy. Then we applied multiple layers of Awlspar spar varnish (M3131 IIRC) as usual.
The benefit of using epoxy first is that it makes the wood much stronger and it can be sanded more smoothly with less risk of sanding through prior to applying the varnish. The varnish adds a slight tint and provides UV protection.
"Naoma" 1988 Ericson 38-200 San Diego, CA
Formerly of: "Maria T" 1987 C25 SR WK 5695 San Diego, CA L DOCK ARMADA
Sounds interesting - Looks great ! Have not heard of that technique before using epoxy. I would also be curious as to the maintenance required after years of use. How does it weather and what does it take to refresh ? After years of use, does it tend to peel, etc and then how hard to touch up or redo ?
It might be mentioned that with many of those woodworker-mariners who build small boats, kayaks & canoes using the various epoxy-saturated wood techniques, it's common to leave some or all of the work bright, and UV-blocking varnish is the standard finish. There've been plenty of vessels built this way, and the ones I've admired continue to look beautiful with periodic revarnishing.
I typed a detailed reply earlier but don't know why it didn't post... Anyway the gist of it was that this wasn't my idea (the epoxy thing). I learned it from professional captains of much larger/nicer yachts (think 100'+). That doesn't necessarily mean it will work on our little boats where there is no full time crew to constantly tend to the finish but so far so good after about six months or so of uncovered exposure to direct southern california sunlight.
The epoxy will certainly give the wood a little extra protection, but the maintenance will still be on the varnish schedule. I tried it on a locker that was frequently wet in the interior of a previous boat with an attractive and durable result, but I'm to lazy for exterior varnish.
Yup! I'd be too lazy for exterior varnish too if I didn't have an amazing wife with high threshold for sanding...
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Dave5041</i> <br />The epoxy will certainly give the wood a little extra protection, but the maintenance will still be on the varnish schedule. I tried it on a locker that was frequently wet in the interior of a previous boat with an attractive and durable result, but I'm to lazy for exterior varnish. <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
