 lead keel or iron keel?
frants
Initially Posted - 11/02/2011 :  20:03:48  Show Profile  Visit frants's Homepage
How do I find out what the keel is made of on my '83?
blanik
Response Posted - 11/02/2011 :  20:15:35  Show Profile
i guess a magnet would answer that
Chris Z
Response Posted - 11/03/2011 :  05:46:48  Show Profile  Visit Chris Z's Homepage
If it is a swing keel it is steel. I think the fixed keel is lead. Someone I am sure can weigh in on the fixed keel to give you a defininate.
Response Posted - 11/03/2011 :  06:44:41  Show Profile
Hmmm... '83 was about the time of the changeover from the iron fin to encapsulated lead (maybe '84). If you don't have any rust, it almost has to be lead. And if you tap it with a hammer and it goes " ", it's lead. The encapsulation is a thick layer of fibrous material--not ordinary fiberglass. BTW, the swing keel is cast iron, not steel.
Edited by - Stinkpotter on 11/03/2011 06:45:20
Tomas Kruska
Czech Republic
Response Posted - 11/03/2011 :  07:22:38  Show Profile  Visit Tomas Kruska's Homepage
Is that cast iron fixed keel somehow encapsulated?
I have a little rust spot on the bottom of the keel but as it now sits on the trailer, I'm not able to check.
Response Posted - 11/03/2011 :  08:38:37  Show Profile
I believe the cast iron fixed keels were attached with non-stainless steel bolts and they switched over to stainless steel bolts when the switched to a lead keel. If your studs/nuts resemble a pile of rust you probably have a cast iron keel. There may have been some cast iron keels installed with s/s hardware or lead keels with non s/s hardware but I have never heard anyone mention having those configurations. Others can chime in if my assumption is wrong. Check the studs with a magnet. S/S is nonmagnetic.
Response Posted - 11/03/2011 :  13:40:42  Show Profile
<br />I believe the cast iron fixed keels were attached with non-stainless steel bolts and they switched over to stainless steel bolts when the switched to a lead keel.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">True.
Response Posted - 11/03/2011 :  15:11:38  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Is that cast iron fixed keel somehow encapsulated?
Tomas,
I also have a 1978 fin keel and mine is not encapsulated. When I had mine pulled this year for a bottom paint job I had a little rust and growth at the very bottom of the keel but was remarkably amazed at the general overall good condition of a 33 year old keel that has been in salt water continuously. I took a wire wheel to the rusted ares and coated them with Hammerite Rust Cap Paint (had a quart in my garage). They painted over that the next day and she is back in the water so I can appraise it in another 4 or 5 years. If all you have is a little rust on the bottom of a 33 year old keel I think you have very little need for concern. At the very least it is something you can address the next time she is pulled. I do not know if Catalina offered encapsulation of the fin keel for that vintage boat. I would expect those that have encapsulated hulls took it upon themselves.
Edited by - Sloop Smitten on 11/03/2011 15:21:16
Response Posted - 11/03/2011 :  18:17:00  Show Profile
I think the lead keel was encapsulated to keep its dimensions the same with the denser lead.
Edited by - Dave5041 on 11/03/2011 18:17:24
Response Posted - 11/03/2011 :  20:23:14  Show Profile
<br />I think the lead keel was encapsulated to keep its dimensions the same with the denser lead.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Agree. That would explain the thickness of the encapsulation, which would not be there for performance purposes. I've seen a couple of damaged encapsulated C-25 keels, and there's a lot of "stuff" on there.
Edited by - Stinkpotter on 11/03/2011 20:23:43
Response Posted - 11/04/2011 :  06:04:44  Show Profile
<br /><blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Dave5041</i>
Yep...
Response Posted - 11/04/2011 :  07:50:23  Show Profile
Yup--that's the stuff... I got into trouble here once suggesting that the "stuff" seemed almost identical in texture to the molded asbestos "blanket" on an old furnace I once had. I still suspect that's what it was, although perhaps done with chopped glass fibers instead of asbestos. (That turns out to be almost as dangerous.)
Edited by - Stinkpotter on 11/04/2011 07:53:09
Response Posted - 11/04/2011 :  11:04:08  Show Profile
I have a bad habit of overstating the obvious . . .
So how do you evacuate all of the moisture once it has entered the above?
Response Posted - 11/04/2011 :  12:11:54  Show Profile
A chopper gun seems a likely technique.
Response Posted - 11/04/2011 :  13:16:43  Show Profile  Visit Prospector's Homepage
OJ - let it sit for a few months, then send to boatyard for repair. Indoor storage helps. They grind back to beyond the damaged area and repair.
Get out chequebook and bend over.
frants
Response Posted - 11/11/2011 :  16:22:50  Show Profile  Visit frants's Homepage
Thank you all!
frants
Response Posted - 11/12/2011 :  16:06:05  Show Profile  Visit frants's Homepage
yep, sure did :-D<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by blanik</i>
<br />i guess a magnet would answer that
