I'm looking for whisker pole suggestions for the C250. I only have a 110, so it does not need to be long or adjustable, especially if I attach it to a stanchion or lifeline instead of the mast. Are there any good homemade alternatives (PVC pipe, maybe)? If so, what type of end fittings are available?
Any other suggestions? What else do you guys do to help downwind performance?
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by DaveR</i> <br />I made one from a $50 telescoping paint pole I got from Lowes. Works great in lighter to medium air. <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Got any pictures and a model # of the pole? I've been toying with using one of the fiberglass poles they sell at HD.
I took a short piece of 1/2 inch schedule 40 pvc, filed it to fit the extension housing, took the aft end of the (shackle?) to a grinder making it a stub and then mixing some good 2 part epoxy and filling the pvc around the shackle. I also drilled 2 small holes through the pole housing and used a couple stainless screws to secure it. I put another shackle on the other end but I think Tom Curran did his better using a small straight metal shaft on the other end for quick capture/release of the sail.
For my Cat. 22, I have in the past made a whisker pole out of a wood closet dowel, adding a snap shackle at one end and a U-shaped tool holder on a screw post to the other end. Total cost was less than $15. Could have used snap shackles on both ends. The snap shackle was a simple brass one with a loop at the other end. Cut a groove in one end of the pole and slid the loop into the groove. Then put a bolt through the pole and loop to hold it in place. It didn't look pretty but was functional. And being wood, it floats!
There are a few drawbacks. Either end of the U-shaped fork will go through ther clew of the sail and hold fairly well, but it can also torque the bracket and break it. Took several years, but it did happen to me once. also, you can let the sheet run in the fork, but if you don't keep tension on the line, the pole can separate from the sheet. Just takes a little bit of extra attention on the sail trim. Good luck! Here are pics:
As I said, it's not pretty, but it works and floats. The pole is 11.5 ft. long, might work with a working jib, but I wouldn't try it with a genoa on a C-25 or 250, pole is not long enough. Also, I need to put a shorter bolt on the spring clip end.
