 4 Batteries?
Peregrine
Initially Posted - 08/30/2011 :  16:26:12  Show Profile  Visit Peregrine's Homepage
<font face="Comic Sans MS"><font size="2"><font color="navy"> I am considering adding to my battery array.
Does anyone have more than 2 batteries?
If so how, why and where.
Any and all info would be appreciated including how you recharge them.
Thanks</font id="navy"></font id="size2"></font id="Comic Sans MS">
John Gisondi
Peregrine
#4762
Response Posted - 08/30/2011 :  19:45:58  Show Profile  Visit aeckhart's Homepage
Can't imagine needing two additonal batteries. Wouldn't it be cheaper to add a solar charger to keep two batteries charged. I've been using one for several years and have had no problems keeping two fully charged batteries thoughout the sailing season.
Response Posted - 08/30/2011 :  22:15:56  Show Profile
I had 5 batteries on my c25... Worked well. Put them under thee aft berth in locked down boxes with a one- two-all switch. But I was always a cruiser.
Sten
Response Posted - 09/03/2011 :  06:32:33  Show Profile
John,
If you had four batteries, how would you choose to set them up?
Some folks double group 24s to provide 150 AH at 12V, so you could set them up as two pair: an A bank and a B bank.
Others might set up two batteries in series to provide 24 volts to your boat's electrical system, and parallel those. But if all your electronics run on 12V, you're setting yourself up to change out everything. Not recommended.
Going back to the first example, setting up two sets of 12 volt parallels is pretty straightforward - you'd essentially have one pair as bank A, the second pair as bank B. So you could use a 1 - 2 - Both - Off switch.
It is always advised that both batteries in a pair be of the same type, brand and age. If not, the weaker one(s) will wear down the stronger one(s).
Goes without saying that you should fuse each battery right at the (+) terminal with a 40A or 60A fuse, but I said it anyway.
If you set it up, I'd recommend you write it up, take a few photos and submit it for publication.
Response Posted - 09/03/2011 :  07:15:53  Show Profile
John,
You can find some real expert sailboat battery discussion on Sailnet.com
Response Posted - 09/04/2011 :  08:45:51  Show Profile
And John, please be kind enough to share what you learn from the experts on Sailnet.com so we can all benefit from the knowledge.
