 traveler sheaves
calden
Initially Posted - 09/06/2010 :  05:57:37  Show Profile
Hey all:
Looking to do a cheap replacement. My '83 C25's traveler has lost a sheave and the other two are cracked and ready to go. The two on the traveler bar are slightly larger than the other one, look to be nylon sheaves.
I can't find direct replacements on Catalina Direct, but I'll call them tomorrow (today's Labor Day) and see. Of course they DO have the entire traveler car assembly replacement, but that's $50, and if I can just find sheaves I can save some money.
Anyone done this? Find another source?
Carlos
Response Posted - 09/06/2010 :  11:22:32  Show Profile
Carlos - the four sheaves will probably cost close to $50 (my two for the masthead were $52.50) I suggest that you get the whole assembly.
Harleyworker
Response Posted - 09/08/2010 :  08:56:33  Show Profile
Calden,
if you find a cheap source for the sheeves let me know, I think mine are the original ones and are failing apart cause they are so brittle. Or if you can find an alternate fix that will work.
andy
Response Posted - 09/08/2010 :  09:18:38  Show Profile  Visit andy's Homepage
I've purchased masthead and stock traveler sheaves from Catalina Direct. Fairly reasonable $$.
Response Posted - 09/08/2010 :  11:22:19  Show Profile
I think you can get away w/o sheaves on the traveler...when adjusting, we position the car by hand and just adjust the lines that hold it in place...
calden
Response Posted - 09/08/2010 :  11:51:34  Show Profile
I ordered some nylon sheaves from Duckworks that look like they will work. About $11 with shipping. I'll need to try and drill out the riveted sheaves that are there now, and replace the rivets with SS machine screws and locknuts. If this doesn't work I'll order a new traveler at that point. I'll report back.
Carlos
Response Posted - 09/08/2010 :  12:48:29  Show Profile
Somewhere in Techtips or a forum post there are dimensions and possibly a part number for the traveler sheaves as a stock item bare sheave from West Marine. I replaced mine several years ago. Drilling out the rivets is the only painful part.
Response Posted - 09/08/2010 :  16:53:44  Show Profile  Visit Leon Sisson's Homepage
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Dave5041
<br />Somewhere in Techtips or a forum post there are dimensions and possibly a part number for the traveler sheaves as a stock item bare sheave from West Marine. I replaced mine several years ago. Drilling out the rivets is the only painful part.</i><hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote"><font face="Times New Roman"><font size="3">I rebuilt my stock Catalina traveler car with general purpose ballbearing sheaves. It now runs very smoothly on the round bar.
I used: <ul><li>(2) Harken #277 "Micro" (bare sheave, 7/8"OD, 3/16"ID, 13/32"W),</li><li>(2) Harken #160 "Bullet" (bare sheave, 1-1/8"OD, 1/4"ID, 1/2"W),</li><li>(2) #10-24x1-1/2" machine screws with self locking nuts,</li><li>(1) 1/4-NCx1-1/4" machine screw with self locking nut,</li><li>misc. flat washers, lock washers, etc. as needed to fit.</li></ul>The 1/2" wide Harken #160s ride on the underside of the traveler bar -- those are your monorail wheels. The Harken #277s are for the 3/16" 2:1 traveler control lines, and are held by the same #10-NC machine screws as the Harken #160s. Where the mainsheet shackle attaches to the top hole in the traveler car, I have only a stainless steel bushing around the 1/4" bolt -- no sheave.
I ground the peened ends off the stock rivets and drove them out with a punch. Don't loose any tiny parts! The rivets were replaced with the #10 machine screws.
</font id="size3"></font id="Times New Roman">
Response Posted - 09/08/2010 :  18:11:32  Show Profile
You can drill the heads off the rivets either by going with a drill bit slightly smaller than the head of the rivet OR you can use a much larger drill bit and drill slowly until the head of the rivet starts to get loose. I prefer going with a larger drill bit that is very sharp.
Either way once the head gets loose use a punch to knock out the body of the rivet.
