 thru-hull questions
calden
Initially Posted - 06/20/2010 :  10:49:26  Show Profile
Hey all:
The new owner guy here. Been working to clean up and fix up the boat, an '83. Have some questions about these things:
First one: Is this the kind of thru-hull that is needing to be replaced (i.e., the Catalina Direct "glass volcano" installation method)?
Depth or knotmeter - which? And also there is a tiny leakage coming from this one. A couple of tablespoons a day. Dangerous?
And... depth or knotmeter?
It was like a Summer in Edinburgh when I stepped the mast...
Thanks tons,
Carlos
S/V Mazama
1983 FK SR
#3682
mlg3733
Response Posted - 06/20/2010 :  11:30:19  Show Profile
#1: Yes
#2: Depth
#3: Speed
#4: May look like a summer in Edinburgh, but the setting sure looks appealing.
Response Posted - 06/20/2010 :  17:25:20  Show Profile
It would be worth re-bedding the next time the boat is out of the water, but I wouldn't worry about it during this season. You may have a volcano, but it has a good seacock on top. I don't have volcanos, so I wasn't sure.
Response Posted - 06/21/2010 :  04:10:45  Show Profile
Looks like the seacock has been replaced by a PO. If it's not leaking and the handle turns easily, I would not worry about it. Deal with the leak on your next haulout, meanwhile keep a shop towel or big sponge down there to collect the water. If it gets too annoying, haul out early and address the problem.
skrenz
Response Posted - 06/22/2010 :  12:31:23  Show Profile
Guys, what he pictures is NOT a seacock Its some sort of ball valve put on top of the original glass volcano through hull. A seacock has a base that bolts to the hull. That's its reason for living, to supply a better mechanical bond to the hull. Looks like the PO had the original gate valve, usually bronze, replaced by this Marleon ball valve. Fixed the original problem but didn't address the underlying structural issue.
Response Posted - 06/22/2010 :  12:43:20  Show Profile
Well.. I don't get it, seacock or ball valve.. My 84 had the exact same thing, and I replaced them ( or glassed them over ) and upon inspection they were fine. Granted, my boat was used very little, and was always in fresh water, but everyone said "oh you better get those replaced."
I would not want anything bumping them inside the boat, and as old as they are I'd rather have them replaced, but I don't look at them as failing.
Again, Salt Water may have a different outcome.
This was another thing that had me worried over nothing. Get it replaced, but don't worry yourself in the meantime.
IMHO
calden
Response Posted - 06/22/2010 :  18:27:48  Show Profile
Thanks all for the suggestions. I had our marina guy look them over and he said they're fine, but don't put an anchor in there. :)
I'm having him, sometime in the next month, haul the boat to paint the bottom, and he'll put in proper thru-hulls at that time.
Went on the maiden sail today with my family (delayed Father's Day.) Did not sink. Enjoyed the boat with a practically new main and extremely serviceable 150 genoa. The family pronounced it "just right" for the size.
Carlos
Edited by - calden on 06/22/2010 21:36:31
Response Posted - 06/23/2010 :  09:50:21  Show Profile
I just had a thought ( it happens ) ..
They are probably installing the through hull they removed off my boat onto another... The part is probably good, it is the skill of the person doing the install that makes it work properly.
Response Posted - 06/23/2010 :  13:43:39  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by calden</i>
<br /> . . . I had our marina guy look them over and he said they're fine . . . I'm having him . . . put in proper thru-hulls . . .
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Just in case your marina guy is a hack:
http://www.pbase.com/mainecruising/replacing_thruhulls
http://www.pbase.com/mainecruising/backing_blocks
Edited by - OJ on 06/23/2010 13:46:15
Happy D
Response Posted - 06/23/2010 :  17:20:33  Show Profile
I do not like the way he installed the seacock. He bolted the valve to the backing plate only? What's the purpose for that. The flange should be bolted through the hull.
I like the ones I put in. They will never corrode. They are bolted to the hull. They can be replaced without removing the king nut. What's not to like?
http://members.csinet.net/dhapp/th/through.hull.html
