I've noticed this regarding my 9.9 Evinrude - same vintage and company as your Johnson. I have a 6 gallon steel tank which is fully enclosed - no pressure release which operates pefectly. I also have a 6 gallon plastic spare tank. When this tank is in use the pressure inside the tank has to be released by opening a plug. If I don't remove the plug the engine slows than stops. Once I looked down and the tank was nearly collapsed because of the fuel pump sucking gas, and air, into the engine.
check prop and rubber hub inside it around the shaft. i may be spinning shaft but not positively turning the prop. rubber may be slipping in prop.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Guero</i> <br />Hello All,
I recently purchased a Catalina 25 1982, Standard Rig. It has an 2 strokes outboard Johnson Sail Master 9.9 (Unknown Year).
Yesterday, we were 6 in the boat and while motoring out of the port to the sea, I noticed that I was not doing more than 3 knots with throttle to almost 3/4 to the max.
3/4 will usually give me 4 to 4.5 kts on 3/4 throttle, on a flat, 0 wind sea.
Is my engine "tired" or this is the average performance I should expect from a Johnson 9.9?
Not that I am in a hurry but with waves on the gulf and upwind, 3/4 will give me around 3 knots.
Your opinion? <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
