 Cleaning lines
zebra50
Initially Posted - 11/06/2009 :  19:10:57  Show Profile
I just know that we have discussed this before but I could not find it in the search of topics. Some of my lines, particularly the anchor line, have green mold/slime on part of the line. A few of the other lines have gotten stiff-no wisecracks. Any suggestions on how to wash them??
Jay
Papa's Boat II
250WB #370
Blog:http://zebra50-boilingpoint.blogspot.com
Response Posted - 11/06/2009 :  20:10:40  Show Profile
Somebody once suggested throwing them in a mesh bag and tossing them into a washing machine.
Response Posted - 11/07/2009 :  00:08:53  Show Profile  Visit delliottg's Homepage
I toss them in a five gallon bucket with some laundry soap, let them soak for a day, then agitate with 2x4 to smash them around a bit. It's stunning how much dirt comes out of them, and they're relatively supple. I don't beat them up with the 2x4 too much, I just want to get the dirt out.
I'd imagine tossing them in a mesh bag & washing machine would have much the same result with less effort.
Edited by - delliottg on 11/07/2009 00:10:43
Response Posted - 11/07/2009 :  05:02:39  Show Profile
An old salt once told me he used Woolite liquid fabric sofetner in the washing machine.(That was for the running rigging.) Apparently worked the opposite of Viagra! Might be worth a try.
zebra50
Response Posted - 11/07/2009 :  07:19:13  Show Profile
thanks all I will give it a try
Response Posted - 11/07/2009 :  13:09:47  Show Profile  Visit britinusa's Homepage
We just 'laundered' 2 100' anchor lines using the mesh bag technique. Worked a charm, the rest of the lines are now 'in line'
Response Posted - 11/07/2009 :  17:04:55  Show Profile
Could you also put them into the dryer with a fabric softener sheet?
Response Posted - 11/07/2009 :  18:26:00  Show Profile
I'm thinking the heat might be a problem -- not sure. I wouldn't do it. I'd hang 'em and let them air dry.
Response Posted - 11/07/2009 :  20:22:44  Show Profile
We put lines in a tub with water and Simple Green and swish it around a bit. I'll give the lines a couple of rinses as well. We clean the lines at the end of each season.
jbkayaker
Response Posted - 11/09/2009 :  16:55:15  Show Profile
Just a reminder that Simple Green will corrode aluminum.
Response Posted - 11/09/2009 :  21:05:57  Show Profile
That's interesting. We washed a friends Cessna 182 for years using Simple Green and water. Never had any corrosion problems. Maybe the paint protected the surface.
jbkayaker
Response Posted - 11/10/2009 :  10:58:23  Show Profile
I saw for myself the effects of Simple Green on the aluminum top of my Miata engine. After using Simple Green the aluminum was dull and rough. It was only on the surface for 10 minutes or so. Here's a quote from a Simple Green rep found at
http://velonews.com/article/9216
"The new product, called ExtremeSimple Green Aircraft & Precision Cleaner, has heightened non-corrosive qualities, making it perhaps more suitable for high-tech bike alloys, painted surfaces, rubber and plastic parts. To date we have only promoted this product in the aviation industry. If it turns out to be better for bicycles and bike parts as well, then we'd certainly like to let people know about that.
Denise Dochnahl
Marketing Specialist
Simple Green"
If you read between the lines here and elsewhere it sounds to me like an acknowledgment by the company that there was a corrosion problem. Their spin is that they altered the formula to give it heightened non-corrosive qualities.
jbkayaker
Response Posted - 11/10/2009 :  11:04:09  Show Profile
It has been brought to the attention of the U.S. Army
> Aviation Missile Command (AMCOM) Depot Maintenance
> Engineering Team that numerous units are using the
> commercial product SIMPLE GREEN as an aircraft wash.
> STOP! This product has been through Department of Defense
> (DOD) testing and was determined to be highly corrosive
> on aircraft aluminum and also a catalyst for Hydrogen
> Embrittlement in high strength aircraft alloys.
> Mr. Richard Cardinale, corrosion@amcom-cc.army.mil
> (361)961-4041, DSN 861-4041
> http://safety.army.mil/pages/lessonslearned/simplegreens.html
jbkayaker
Response Posted - 11/10/2009 :  11:06:32  Show Profile
http://www.autopia.org/forum/car-detailing-product-discussion/59319-simple-green-aluminum-embrittlement.html
I wouldn't want to ride in that Cessna.
Edited by - jbkayaker on 11/10/2009 11:13:58
Ed Cassidy
Response Posted - 11/10/2009 :  12:32:50  Show Profile
I believe Simple Green has instructions for it's use that call for a 30 to 1 mix for much of it's intended uses and I coud see where it probably gets used full strenght most of the time. Its probably one of those products that you either love or hate but either way you you are sure it causes problems or you insist it doesn't. I preffer to look at the Material Safety Data Sheet for these products and in this case, it shows an un-diluted PH of 9.5 and that it won't cause you to go blind if sprayed in the eyes. You can even reuse the bottle it comes in for other stuff. Sounds quite safe and non-corrosive to me but I've never used it.
Response Posted - 11/10/2009 :  19:02:15  Show Profile
We always diluted the simple green when we washed the plane. Besides it was sold over 20 years ago so it's not a worry for me.
