 Jiffy reefing system
gracer
Initially Posted - 07/24/2009 :  14:21:47  Show Profile
Can anyone send me a diagram for the proper set up of the jiffy reefing system. I seemed to have forgotten how to rig it
Bob
Bob Grace
Castleton, Vermont
1984 Swing Keel "Sara"
Response Posted - 07/25/2009 :  19:38:04  Show Profile
There is no proper way, there are a hundred ways. People who are happy with their reefing system are happy because they have created one that meets their needs. Figure out what you want it to do, buy the hardware you need and build it. Remember the stock rigging changed over years and was always cheap and minimal. You can do better.
Response Posted - 07/25/2009 :  20:11:07  Show Profile
Of course, Frank's probably right but, if you look in the owner's manual for the C250, (Under "Manuals & Brochures" in the upper left of this page) there is a diagram of a suggested system. That will given you a jumping off point. You can also search the forum for others' ideas. This has been discussed a lot here so, you'll find lots of ideas.
Response Posted - 07/25/2009 :  20:12:21  Show Profile
Here is Catalina's description for 2-line reefing (from the Manuals and Brochures section here):
The single-line version simply runs the line from the aft end of the boom past the cleat to a turning block at the forward end of the boom, then up through the reef tack grommet and down to a cleat on the other side of the mast--or through mast-base blocks and a deck organizer back to a clutch on the coachroof by the cockpit.
I prefer the two-line version so the tack end can be set first, allowing good tension on the clew without pulling the lower slug out of the mast slot. Both lines shown can also be led back to the cockpit.
Edited by - Dave Bristle on 07/25/2009 20:15:42
dflynnatc
Response Posted - 06/17/2010 :  09:43:14  Show Profile
Dave, searched and been interested in this thread. In the picture presented, what then do the middle grommets do? Do you then just use some ties on them? Or is the two line just for the tack and clew?
<br />Here is Catalina's description for 2-line reefing (from the Manuals and Brochures section here):
Response Posted - 06/17/2010 :  12:46:32  Show Profile
The middle grommets are for <u>loosely</u> tying the bunched sail, not that everyone does.
sfsmith
Response Posted - 06/17/2010 :  14:23:18  Show Profile
I use pieces of shock cord, knotted on either side of the sail. When they're tied under the boom they tidy up the sail, but there's still some give so the grommets don't tear out.
skrenz
Response Posted - 06/17/2010 :  15:33:31  Show Profile
The latest issue of SAIL magazine has a good article discussing the pros and cons of single verses double line reefing. It offers some suggestions for cutting down on line friction and offers an intriguing way of improving single line reefing. The article is by Brian Hancock and is under BoatWorks, Upgrades.
dflynnatc
Response Posted - 06/17/2010 :  18:39:32  Show Profile
This really helps..... thank you SO much.... makes more sense!
<br />The middle grommets are for <u>loosely</u> tying the bunched sail, not that everyone does.
Tom Gauntt
Response Posted - 06/18/2010 :  11:04:06  Show Profile
Here is a good link from Mauripro sailing about various rigging techniques from Harken. Gives some good solutions to vangs, outhauls, reefing, cunning hams, spinnakers, etc.
http://www.mauriprosailing.com/Harken/harken-trimming-systems.htm
Response Posted - 06/19/2010 :  09:28:03  Show Profile
Not surprisingly, I use the reefing system drescribed by Dave Bristle, DPO, <i>Passage</i>, shown above.
I noticed a slight inaccuracy in the original Catalina illustration that is, nonetheless, quite important for sail shape when reefed.
Anybody who plans to install their own reefing system on a C-25 would be well advised not to take the picture's geometry as gospel.
The angle that the cheek block makes with the reefed clew grommet should be such that it pulls the clew eye down <i>AND AFT</i>, in the same direction as the outhaul. This will pull the reefed sail's foot taut along the boom.
The picture incorrectly shows the cheek block positioned <b>forward</b> of the reef clew grommet. This would pull the clew grommet downward, but also forward.
The cheek block (on the starboard side) and the corresponding padeye (on the port side) must both apply downward force to bring the reefed clew grommet down to the boom, but must also apply force aft.
If you install your own jiffy reefing system, make sure to place the padeye and cheek block far enough back on the boom to get about a 45 degree angle on the reefing line.
As mentioned above, once the tack and clew are set, the in-between grommets are not critical to sail shape, but these reefs are simply there to manage the excess sail on the boom.
Response Posted - 06/19/2010 :  10:38:49  Show Profile
<br />I noticed a slight inaccuracy in the original Catalina illustration that is, nonetheless, quite important for sail shape when reefed. Anybody who plans to install their own reefing system on a C-25 would be well advised not to take the picture's geometry as gospel. The angle that the cheek block makes with the reefed clew grommet should be such that it pulls the clew eye down <i>AND AFT</i>...<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">I noticed the same thing and forgot to point it out this time--good catch. What I don't remember is how far aft of the reef clew the cheek-block was mounted on Passage's boom... Bruce?
Response Posted - 06/19/2010 :  20:07:33  Show Profile
I checked it today and the cheek-block looks to be about 4" aft of the reef clew.
DanM
Response Posted - 06/21/2010 :  06:07:43  Show Profile  Visit DanM's Homepage
Dave and Bruce - Perfect Day has the same setup, with the padeye and turning block set aft. But the PO left me a spiral horn to attach the tack. Works OK when reefing at the dock, but a real hastle when underway. Running a simple line up and thru the reeftack eye, as in the two-line drawing would be so much easier. I think I have that set-up also, but never considered it. Thanks!
