Yesterday I was sailing in steady 10-15 mph winds and having a blast. The one thing that was puzzling me (well maybe more than one) is the sail shape and trimming. No matter what I did the trailing edge of the mainsail would flap between the 2 and third stays when the wind would blow steady or gust. I did notice that I had a 40-45 degree twist in the main which I couldn't seem to change either. The vang was tight as was everthing else? Where should I have started to try and trim it out. The genoa was doing the same as well but I had it about 20% furled.
Is this normal or are there things I can do to get both sails quiet and tight?
1986 C-25 FK Tall Rig "Blue Nose" Mobjack Bay, Virginia
Where was your traveller? High side or low side, and how far over?
How old and stretched are your sails?
What were your streamers doing?
How much backstay tension did you have?
If I were guessing, I would guess that you didn't have enough backstay tension and that your traveller was too far over on the leeward side, and that you should have pulled in your mainsheet more. Not being there makes this all conjecture.
If you had of hardened your sheets and sheeted to the high side, your boat would have leaned more. The backstay tension would flatten the sail a bunch, which would have acted to make it possible to let the sheet out until you got the right balance of heel and power.
there is something called a leech line which is a very fine line sewn into the back of the mainsail. Tighten this up to stop the flapping but don't cup the sail. This helps flatten a worn sail.
Sounds like way too much twist! Harden the halyard, tighten outhaul, no topping lift, vang on. Backstay medium-hard if you got an adjustable (but then your rigging needs to be tuned properly for an adjustable backstay).
On my boat the previous owner had tied off the traveler in a stationary position. It is centered. I will have to replace the line to make it adjustable. Halyard was hard, outhaul was tight, topping was slack. The adjustable backstay isn't even hooked up - maybe that is the culprit???
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Blue Nose</i> <br />How do you tighten the leech line?<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
If your sail is equipped, the leech line, usually just a small diameter cord sewn into the leech of the sail, is adjusted on the sail itself. My main has a small nylon clam cleat device sewn into the sail to fasten the line. To adjust, simply tighten the leech line until the fluttering stops.
Blue, My main does not have a leech line and it flaps continuously between the 2nd and 3rd battens in winds 10 knots and above. No amount of tweaking the traveler, vang, halyards or sheets has eliminated it. You can have a loft install a leech line but other than that, or replacing the sail, I think your just going to have to learn to love it.
