 Cynthia Woods sinking revisited...
Initially Posted - 10/28/2008 :  14:08:34  Show Profile
I just read that the widow is suing everyone except for Texas A&M.
Texas A&M pulled the sistership and had the boat recovered as well as the keel. The keel bolts were still attached, so it looks like the very thin fiberglass just gave away. I downloaded the ppt file from www.tamu.edu - just search Cynthia Woods...
Looks like very flimsy construction to me...
Sten
DPO Zephyr - '82 C25, FK, SR
SV Lysistrata - C&C 39 - Norfolk VA - headed south
joemireur
Response Posted - 10/28/2008 :  21:42:58  Show Profile
I tried the link and searched there for "cynthia woods" but did not find much information other than the earlier story from when Stone's body was recovered.
Can you offer more light on this subject pliz?
Joe
Response Posted - 10/28/2008 :  21:54:55  Show Profile  Visit delliottg's Homepage
Here's the [url="http://www.oceannavigator.com/ME2/dirmod.asp?sid=&nm=&type=Publishing&mod=Publications%3A%3AArticle&mid=8F3A7027421841978F18BE895F87F791&tier=4&id=5757E47454494ECDAEB312006EB7A8EA"]latest news I can find[/url]. Simply Google "Cynthia Woods sinking" and you'll find all the poop.
Response Posted - 10/28/2008 :  21:57:57  Show Profile
<br />Looks like very flimsy construction to me...<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">...or a "very strong" wood cored keel stub, where the wood became significantly less strong (rotten)
Response Posted - 10/29/2008 :  08:51:37  Show Profile
I found a link to the PowerPoint file where pics were of the boat et al... I coudn't figure out how to transfer the link.... But I went to www.tamu.edu and used the search box and it came up. It is a presentation obviously designed in an open format wherein issues are being addressed. They had a whole section of Preserving evidence for example... It was like 3 megs and is a .ppt file
sten
Response Posted - 10/29/2008 :  09:47:46  Show Profile
Logically, it seems like the <u>designer</u> should be held responsible for providing a design which specifies the materials to be used and the tolerances necessary so that the boat, when completed, will be seaworthy and will be reasonably suited to the boat's intended purpose. (i.e., Lake sailing and coastal cruising, bluewater sailing, racing, etc.) If the designer met that responsibility, then he shouldn't be held legally liable. If he provided a design that was inadequate for the intended purpose, then he should be held liable.
The <u>builder</u> should be held responsible for constructing the boat <u>in accordance with the designer's specs</u>. If he built the boat in accordance with the designer's plans, then the builder shouldn't be held liable. If he used different materials or tolerances than what were specified by the designer, then the builder should be held liable.
If the designer provided an adequate design, and the builder constructed the boat in accordance with the design, then the <u>owner</u> of the boat might be liable for <u>failing to maintain the boat</u> so that it is safe and seaworthy, or for using the boat for a purpose for which it was not designed.
That's another good reason for getting a survey when you buy a boat. If someone is injured or killed on your boat, it can provide some proof that your boat was in a safe and seaworthy condition at the time you bought it. It's also a good reason to think twice before you use a lake sailer or coastal cruiser for bluewater cruising.
Edited by - Steve Milby on 10/29/2008 09:52:47
Response Posted - 10/29/2008 :  09:56:42  Show Profile
<br />...It's also a good reason to think twice before you use a lake sailer or coastal cruiser for bluewater cruising.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">...especially with anybody other than yourself aboard.
Response Posted - 10/29/2008 :  11:33:30  Show Profile
From a news account...
"The university confirmed that the Cynthia Woods had run aground as many as six times before the fatal incident.
They said the vessel suffered significant keel damage a year ago."
Response Posted - 10/29/2008 :  12:16:03  Show Profile
There you go.
Tom Potter
Response Posted - 12/20/2008 :  17:21:36  Show Profile
Here's a updated [url="http://www.carolinacurrents.com/detail.php?1029"]report.[/url]
Response Posted - 12/21/2008 :  10:47:59  Show Profile
Excellent update and a valuable lesson for us all as well. Those "simple repairs" and "occasional accidents" can add up and, if not done/repaired properly, can devastatingly prove that old saying to be true: "a chain is only as strong as its weakest link!".
Response Posted - 12/21/2008 :  12:07:18  Show Profile
...and, as I've harrassed people about before , hull repairs should be done professionally--especially around the keel (including the C-25 swinger).
Response Posted - 12/21/2008 :  12:09:48  Show Profile  Visit britinusa's Homepage
Thanks Tom, that's a heads up for all of us!
Ed Cassidy
Response Posted - 12/21/2008 :  13:18:07  Show Profile
There is a picture of the recovered keel here.
http://forums.sbo.sailboatowners.com/showthread.php?t=104062&styleid=1
And there are references that point to a commercial boat company reattaching the keel snd that students did further hull work that they were not qualified to do here http://www.khou.com/news/local/galveston/stories/khou081219_jj_cynthia-woods-sail-boat.7a22d557.html I'm not an engineer but from what I see of the keel where it attaches to the hull there is not much on the inside of the hull to keep it in place. I don't think this story is over.
Ed
Edited by - Ed Cassidy on 12/21/2008 14:55:06
Response Posted - 12/21/2008 :  14:41:18  Show Profile  Visit britinusa's Homepage
Thanks for those links too Ed.
The bolts appear to be for the purpose of holding the blub to the fin but there does not appear to be anything suitable for holding the fin to the hull.
Even if the hull were 4" thick, there's a huge amount of leverage against that thin fin/hull connection. I would have expected transverse steel plates in the hull. Wow.
The info from 'Roger' in that first link says a lot.
(please edit out the period(.) at the end of the second link else we get a page not found.
Response Posted - 12/28/2008 :  13:16:56  Show Profile
The pictures tell the whole story as far as I am concerned. There is simply not enough fiberglass on the keel, and the hull break looks pretty clean. The Coasties are obviously hard pressed to blame the builder, but as far as I am concerned this vessel had no business doing anything but getting raced every so often, hauled, inspected and relaunched somewhere else. This vessel should not have been treated like a charter vessel. Modern racing vessels are unsafe (predictable) in my opinion because the builders are designing them too light and pushing the envelope just a bit too much, as a result - stuff breaks.
This makes me worry about all of the other lightweight - read flimsy - vessels out there that have hit the bottom once in awhile. Losing the keel outranks fire as the scariest thing that can happen out there.
Reminds me of the smile that was starting to form on my old C25. The point of attachment for the keel seems as wide as Cynthia Woods... But my bolts were starting to rust a bit and the smile was just starting to form. Has Frank ever had a keel failure?
sten
Response Posted - 12/28/2008 :  16:37:53  Show Profile
<br />...Modern racing vessels are unsafe (predictable) in my opinion because the builders are designing them too light and pushing the envelope just a bit too much, as a result - stuff breaks...<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">...like [url="http://www.youtube.com/watch?v=LA-REPv-ReY"]this[/url]?
Response Posted - 12/28/2008 :  21:55:01  Show Profile
Precisely. Can't make me... Also note that the EPIRB AND LifeRaft were improperly stowed. I think the university is still on the hook..
sten
