 Winches on Coaming
Response Posted - 03/29/2009 :  09:42:30  Show Profile
Here is that photo:
And the angle to the winch:
Nice low angle, no overwrap.
Response Posted - 03/29/2009 :  12:09:59  Show Profile
Hard to see in the photo, but is the sheet between the lead block and the headsail led on the inside or outside of the lifelines? What size is your headsail?
Steve Blackburn
Response Posted - 03/29/2009 :  14:11:43  Show Profile  Visit Steve Blackburn's Homepage
How about that eye right over yor ST40?
Steve Blackburn
Response Posted - 03/29/2009 :  14:14:27  Show Profile  Visit Steve Blackburn's Homepage
Wil, Where did you get that rail mounted block in this picture?:
Response Posted - 03/29/2009 :  21:06:52  Show Profile
The sheet is on the outside of the lifeline and the genny is a 135. Steve the unit on that stanchion is this:
[url="http://www.westmarine.com/webapp/wcs/stores/servlet/ProductDisplay?resultCt=1&jspStoreDir=wm51&catalogId=10001&productId=71915&keyword=1972710&y=0&x=0&storeId=10001&ddkey=SiteSearch"]1972710 Swiveling Furler Fairlead[/url]
Steve Blackburn
Response Posted - 03/29/2009 :  21:25:27  Show Profile  Visit Steve Blackburn's Homepage
Please have a look at these from Spinlock:
[url="http://www.hallspars.com/ItemForm.aspx?item=SPI-WL%2f1&Category=95137972-aebf-4561-abb4-d0a34d5e3802"]Stanchion Lead Bullseye[/url]
SPI-WL/1: $13.23
[url="http://www.hallspars.com/ItemForm.aspx?item=SPI-WL%2f2&Category=95137972-aebf-4561-abb4-d0a34d5e3802"]Stanchion Lead Block[/url]
SPI-WL/2: $28.26
Also many more stanchion mounted hardware: http://www.hallspars.com/Categories5.aspx?Category=95137972-aebf-4561-abb4-d0a34d5e3802
What do you think?
Do I really need blocks or will only going with Bullseyes work?
Edited by - Steve Blackburn on 03/29/2009 21:29:06
welshoff
Response Posted - 03/30/2009 :  10:37:41  Show Profile
Steve,
I believe they are Lewmar. But, I really like the way Randy has his set up. If I did it again, I would lean towards his routing. It is very clean.
welshoff
Response Posted - 03/30/2009 :  10:42:09  Show Profile
Don,
With a 135% on a C250 you have to route jib sheet on outside of standing rigging.
When I am reefed down, I reroute sheets to inside of rigging for a better sheet angle.
Response Posted - 03/30/2009 :  15:02:50  Show Profile
Steve, I like the spring-based blocks because they adjust very well to the angles involved. Also, note that the stanchion-based bullseye is swiveled, not fixed. You want maximum adjustment flexibility to reduce friction while achieving a proper lead angle.
Other hardware may work too, I just know that this setup does work.
Response Posted - 03/30/2009 :  21:09:19  Show Profile  Visit Arlyn Stewart's Homepage
Another simple setup that works.
I made the pair of rubbing rails by halving a piece of round nylon. SS rails are available.
A by product of the rub rails is they provide a slip stopper when coming off the coach roof.
In the pic, the swivel cam cleats are used to handle twings. Twings are jib sheet blocks on the end of a line fed through the jib sheet car. The car is parked and left in the most forward position, which then allows adjusting the height of the twing to simulate moving a jib sheet car. This makes for very easy adjusting of the jib sheet angle.
Note: They can only work if using coaming winches and surprisingly they don't foul.
Edited by - Arlyn Stewart on 03/30/2009 21:11:12
sgarber
Response Posted - 04/30/2012 :  06:45:32  Show Profile
Is a 7c winch able to handle the main halyard? I'd like to move my cabin top winches back to the coaming.
Response Posted - 05/01/2012 :  10:15:08  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by sgarber</i>
<br />Is a 7c winch able to handle the main halyard?
Yes.
Tradewind
Response Posted - 05/02/2012 :  12:37:10  Show Profile
This has worked well with my 150.
