Catalina 25 Year: 1981 Fin Keel, Standard Rig, Pop Top HIN:CTYK2323M81D
LOA: 25' 0" LWL: 22' 2" Beam: 8' 0" Draft: 4' 0" Ballast: 1900 lbs Displacement: 4550 lbs Sail Area: 270 sq ft Hull Material: Fiberglass Coring: End grain balsa, plywood in high stress areas Hull Color: White with red boot stripe; Deck: White with white non-skid Designer: Frank Butler Tanks: Water 16 gal plastic; Fuel 6.5 gal plastic
Location: 1981-2003 Finger Lakes Region NY; 2003-Present Havelock NC
Asking Price: Boat $5900; Trailer $1000
Contact: Richard LaPalme, 252-447-3020, rlapalme@ec.rr.com Moving up to a 32 footer
Engine 2006 Yamaha (T9.9EXH2) High Thrust Outboard, Long Shaft 9.9hp, 4-stroke, 10 hours, 3-Blade Prop, Electric Start, Gasoline Mount: Garelick EEz-In, Heavy Duty 4-Spring, Model 71091 (2006)
Accomodations Sleeps 6, V-Berth (2), Opposing saloon settees (2), full size quarter berth (2) Head: Wilcox-Crittenden Head Mate (rebuilt 2006) Thru-Hulls: 2, upgraded to bronze ball valves from original gate valves Holding Tank: 14 gal plastic; no Y-valve No Shower Interior Wood: Teak with oil finish Cabin Sole: Molded fiberglass liner simulated wood grain Headroom: 5' 2''; pop-top open 6' 3" Upholstery: Durable two-tone marine fabric; beige with blue accents, vinyl bottoms, 3 inch foam Upholstery covers can be unzipped and removed from foam cushions Nylon dry-decking installed under all upholstery for ventilation Heat/Air: None Curtains: Custom made, full length sliding port and starboard, beige with blue accent stripe (2005) Carpet: Wool oriental rug in saloon (2005)
Galley Icebox: standard Stove: Princess 2 burner pressure alcohol with pot hooks and cutting board Oven: none Sink: Single bowl S/S with pressure cold water and custom cutting board Faucet: Scandvik #10172 chrome plated brass 10-inch faucet Domestic Water: Jabsco #31600 40psi, 3.5 GPM fresh water pump (2005) Jabsco #30573 1-Liter Accumulator Tank (2005) All water intake and supply hoses replaced (2005)
Sails Main and 110% Hank-On Jib, professionally cleaned and maintained by Sail Care (2005) Sails exhibit excellent stitching, good feel and have new batten elastic Rolly Tasker Storm Jib (60%), 7oz, 36 sqft Dacron (2006)
Canvas Bimini: Custom 1" S/S frame and S/S fittings Three piece Sunbrella bimini covering Cabin and Cockpit with Connector; Oyster (2007) Mainsail Cover: Sunbrella Oyster (2007) Jib Deck Bag: Sunbrella Jockey Red (2007) Tiller cover: Sunbrella Jockey Red (2006) Cockpit Cushions: 5 piece Custom "Bottom Siders", tan with red accent stripe (2007) Pop-Top covering with vinyl windows in like-new condition
Last Haulout Dec 2004, bottom sanded and painted with two coats of Pettit Altima #1697 Ablative Hull waxed with Colonite #885 Fleetwax
Rig and Deck Hardware Masthead rigged sloop 2 winches, Lewmar #7A, cabin top, (2004) 2 winches, Lewmar #7C, cockpit coaming with Harken #150 Cam-Matic Cleats Tiller: Laminated Wood, Refinished (2004) Fitted with Davis Tiller Tamer Tiller extension: Forespar 19"-32" twist lock extension Rudder: Upgraded Balanced, solid HDPE NACA 0012 airfoil shaped rudder by IdaSailor (2006) Installed 2 new pintles, 2 new delrin gudgeon bushings (2006) Boom Topping Lift: Installed (2004) and cleated on boom Outhaul: Installed Catalina Direct In-Boom 8:1 and led to cockpit (2005) Lazy Jacks Mainsheet: Harken #058 Fiddle w/cam & Becket, Harken #053 Fiddle, 4:1 tackle, (2006) Traveler: Catalina standard equipment Running Rigging: Replaced both halyards, mainsheet and traveler line (2004-2006) Mooring Cleats: Six 6-inch cleats Foredeck anchor cleats: Two Suncor 8" 316-S/S Herreshoff Cleats with S/S backing plates Foredeck chocks: Two Windline LC-1 S/S chocks with S/S backing plates Rigging Turnbuckles: All 8 replaced (2004) with bronze open body, chrome finish Installed S/S Mast Step Halyard Plate (2004) Turning Blocks: Installed 4 Harken #005 Blocks at mast base (2004) Deck Organizers: Two Harken #1500 with two 2-inch ball bearing sheaves Rope Clutches: Two pairs Spinlock XAS Powerclutches on Cabin top Installed Jib downhaul with fairleads and stanchion cleat (2004) Cap Shrouds (2) replaced 2004 Wind Indicator: Davis Windex 15 (2003) Anchor Light: Upgraded to Catalina Direct #Z2004 (2004) Mast Gate: Custom mast gate installed (2005) Solar Vent: Nicro 4" solar-powered vent mounted on forward opening hatch (2004) Deck Washdown Pump: Jabsco #30700 4.3GPM, 50psi with Pumpguard inlet strainer (2006) Deck Washdown Fitting: Jabsco #31911 flush mount S/S (2006) deck fitting with 15' coiled vinyl hose Anchor Holder: Two Windline PM-1 S/S pulpit mounted adjustable brackets for Danforth type anchors Anchor & Rode: 13# Danforth, galvanized; 10' 1/4" chain, 200' 1/2" rope rode Bow eye S/S trailer U-bolt with oak backing block (2004) Lifelines: Vinyl coated S/S lines, 22" stanchions, port & starboard cockpit gates Compass: Saturn #A140 Bulkhead Mount, Dual-Read with lens cover (2004) Mast-Up Support: Custom aluminum mast support for raising and trailoring
Electrical Alternator: 10 Amp (included on Yamaha Outboard Motor) Batteries: Two Group 24 (Apr 04 and Aug 06) Battery Selector Switch: Blue Sea Systems #9001e, 4 Posisiton, OFF-1-BOTH-2 Panel: Catalina DC Panel with additonal West Marine 3-Circuit panel with voltmeter and 12V plug (2004) Solar Panel: Uni-Solar flexible panel #UNF32, 32 Watts (2004) Solar Panel Charger: Morning Star #SS-6 charge controller (2004) Upgraded primary wiring to #8AWG tinned copper from batteries to control panels Cabin Lights: Six 12VDC incandescent overhead mounted switched fixtures
Electronics Uniden Polaris 25W DSC VHF fixed mount marine radio, GPS input capable, installed 2005 Shakespeare Mariner 4200 3' VHF S/S whip masthead antenna (2005) Antenna to Radio coaxial cable: Ancor Marine Grade RG-8U (2005) Blue Sea Systems CableClam through-deck coaxial cable fitting Uniden Wireless Handheld Access Microphone (WHAM) installed 2006 Raymarine ST60 Plus Speed System including transducer, display and wiring (2004) Raymarine ST60 Plus Depth System including transducer, display and wiring (2004)
Sailboat Trailer Trail Rite 1982 Dual Axle with sailboat hull jacks, keel support and extension tongue, hydraulic surge brakes 3 New tires, brakes and axels serviced 2004
