 Dimensions for a 135% furling jib?
monty0
Initially Posted - 07/18/2007 :  18:45:27  Show Profile
Our boat came with a 150% furling jib and its an old monster to handle on our lake. The sail and bowlines on the sheets get hung up on the shrouds especially in light winds. Folks here recommend a 135. We have an older Harkin furling system and I'm looking into purchasing a previously owned sail with some life left in it from Minney's. They have asked me for the dimensions I looking for. Given that I don't have a 135%. I'm not exactly sure what those dimensions would be. Can anyone out there suggest what those dimensions might be?
Monty
1977 Catalina 25 #66 SRSK "Prana"
Response Posted - 07/18/2007 :  19:28:32  Show Profile  Visit Frank Hopper's Homepage
Without getting into a lot of detail, an foot of 13'-14' luff of 25'-28'
My 135 is a full hoist 135 and has a luff of 28' with the furler it makes it a full hoist. Most 135s are not full hoist and with a furler would be around 25' on the luff.
Response Posted - 07/18/2007 :  20:04:29  Show Profile
Frank's also looks like something of a deck-sweeper. My 130 had a considerably higher clew, thus shorter leach It also had about a 10" wire pennant at the head, so it wasn't "full hoist"--possibly due to the requirements of the Hood furler. I don't have the dimensions, since I don't have the boat.
Edited by - Dave Bristle on 07/18/2007 20:09:03
BruceL
Response Posted - 07/18/2007 :  21:32:23  Show Profile
I've been checking a Minny's for the same sail
I don't think that they have one.
I priced it at Ullman and It's around 800.00
at that is for one with a #6 tape and a 28 luff
ajada
Response Posted - 07/19/2007 :  05:30:46  Show Profile
I have a used 135 still good for cruising for sale. It fis a tall rig so it will work on a standard rig. If you are interested...
Arch Altman
82 TR FK #3160
raleighwoodcab@aol.com
Response Posted - 07/19/2007 :  08:38:11  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by ajada</i>
<br />I have a used 135 still good for cruising for sale. It fis a tall rig so it will work on a standard rig...<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
If you amputate it at the knees
Response Posted - 07/19/2007 :  08:52:38  Show Profile  Visit Frank Hopper's Homepage
I used a J-24 150 as a 135 on my '82 Catalina 25. I worked very well and are readily available from local J-24 sailors.
This is a j-24 150 on my '89 It looks to be about 26' in the luff.
Response Posted - 07/19/2007 :  10:27:56  Show Profile
Here's another novice question.
Why is there so much discussion about the size of the sails? What I mean is, the IJPE dimensions are known. The Tech Manuals have the IJPE numbers and the manufacturer's recommended sail dimensions for the 150% and the 110%(Page 9 of the Owner's Manual) Wouldn't the 135% dimensions just be a matter of arithmetic? 150:30::135:X X= 27
Am I missing something?
Edited by - John Russell on 07/19/2007 10:38:53
Response Posted - 07/19/2007 :  10:48:24  Show Profile
<br />Am I missing something?<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Yup.
Response Posted - 07/19/2007 :  11:19:10  Show Profile
Thanks, Dave! That clears it up!
Response Posted - 07/22/2007 :  20:33:25  Show Profile
The percentages for headsails are based on the "luff perpendicular" measurement of the sail in relation to the J dimension of the boat.
[url="http://www.cruisingdirect.com/LP_Measure.htm"]Calculating the Luff Perpendicular[/url]
Response Posted - 07/22/2007 :  21:14:59  Show Profile
That really clears it up for me Don. Thanks. Now I'm just left with the question of luff length. It seems to me that luff length is a specific known quantity, yet, the questions seem to persist. Isn't the luff of the 150, 135, 110, etc, the same? It is obviously dependent on the furler vs. hanked on, etc., but for a given boat, It seems to me that it would be the same. It seems to me that if you shorten the luff then the overall sail area may not actually increase by the amount anticipated. Desirable when looking for a stormsail but a problem when looking to increase sail area.
Response Posted - 07/22/2007 :  21:32:01  Show Profile  Visit Frank Hopper's Homepage
Nope, a 110 anticipates heavy air, to further reduce sail area they have shorter luffs, keep it low in a blow or you will heal and go slow. Big genoa are all about getting as much sail up as high as you can to catch the air; a 135 is a compromise. I have a custom 135 that is full hoist and a deck sweeper because I want the maximum sail area with the least overlap, I sail in heavy wind most of the time and this is what I wanted my furling sail to be.
Edited by - Frank Hopper on 07/22/2007 21:33:53
Response Posted - 07/23/2007 :  11:06:22  Show Profile
The other principal variable related to the leach and the foot dimensions is the height of the clew. Racers with hank-ons want deck-sweepers, while cruisers with rollups generally want the better visibility and easier handling of a higher clew. (It also rolls up better.) Thus, the LP measurement can be from different points along the luff, and the other two measurements will vary accordingly.
Edited by - Dave Bristle on 07/23/2007 11:11:06
monty0
Response Posted - 07/23/2007 :  17:30:15  Show Profile
I'm wondering about the length of the leech for a 135. Is there some formula to figure that outL I see with my Harken MK11 Jib furling system I have a eye to eye sail length of 27'7", I'm thinking I want a foot of 13 or 14 feet.
Thanks for the informatrion so far!
Response Posted - 07/24/2007 :  00:46:12  Show Profile  Visit Frank Hopper's Homepage
The leech is your call, it is a personal preference. I have a really long one for maximum sail area. Many want high clews as Dave said, you need to make that call yourself.
