 Remote controls and raising the engine
Jmurfy
Initially Posted - 06/03/2007 :  00:34:11  Show Profile
I have a 1998 Yamaha 4 stroke on my C25 with remote controls. My problem is if I lift the motor out of the water with my CD Garelick mount the throttle and gear shift linkage go out of adjustment due to the strain put on the cables by the angle of the lifted motor. Has this happened to anyone else and are there any suggestions to fix this problem?
Bill Holcomb
Response Posted - 06/03/2007 :  10:30:45  Show Profile
Don't know the answer for sure - but in the "old days" we used to put about a 1-foot diameter loop in the control lines for outboard engines so that the cables wouldn't bind when the engine was tipped up or turned.
sweetcraft
Response Posted - 06/03/2007 :  23:30:03  Show Profile
It worked for me and everything came through the same hole in the stern.
Jmurfy
Response Posted - 06/04/2007 :  18:42:00  Show Profile
Thanks. I was thinking about that also and wondered if it would work. I need to check if I have enough cable for the "loop".
