I am computing the electric needs of my boat in order to determine what amount of battery power I need. I have the data for my depth finder, speed meter, GPS Chartplotter, and Autopilot. Now I need the AMP draw for the interior lights, running lights, anchor light, and propane solenoid. Do any of you have that information? Thanks.
Well, I used to be a simpleton but I'm trying hard to be a genius. Plus, I plan to go with AGM batteries and, at $200 each, I would prefer not to over buy. And I would like to know ahead of time what my ability to be away from shore power is and what options I have. So, while I appreciate the "all that can fit" approach I would like to be a little more analytical this time.
fluorescent light 0.7 amp incandescent lt. 2.1 amp anchor lt 0.8 amp gas solenoid negligible gas detector 0.3 multiply each one by the hrs of use and the number of each item you have aboard to get the amp hrs
<font color="blue"><font size="4"><font face="Comic Sans MS">Well at least I'm not responding to this post 6 years later.
Use a volt meter which is also an Amp meter and disconect the positive lead on the battery. Switch the volt meter to Amps. Connect the positive lead of the volt meter to the positive post on the battery. Connect the negative lead on the volt meter to the positive battery cable. Switch on each device and read the Amps.
paulj C250 WK # 719</font id="Comic Sans MS"></font id="size4"></font id="blue">
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Well at least I'm not responding to this post 6 years later.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
i believe pauls way is the better way to determine your amperage draw. mine came from a table. dont forget to multiply the hours you use the device each day
