One of my winter projects is to mount a wind direction indicator on the top of the mast. I was out at the harbor in Newport, Oregon and spent a lot of time looking at the top of masts to see how to mount the Windex. It seems like the most common way is to use the extension arm and mount it on top of the masthead. Has anyone had experience drilling into the top of our masthead to mount a Windex? I'am not sure what the masthead is made of and whether I'll ruin it by drilling into it. Another option, of course, is to drill into the mast itself. What's the best way to go? As an aside, it was fun to walk the docks in Febuary and look at boats that have stopped in from Seattle to Honolulu. We often have a couple of nice weeks in early Febuary before the storms roll in again. It's enought to make one think Spring is just around the corner.
I have used several methods and the drill and tap is excellent and probably the best, be sure you are verticle when you drill, the angle will be exaggerated by the length of the windex mast.
I used one of the pre-existing holes. Replaced the pin holding the topping lift sheave with a stainless bolt/locking nut... a lightweight piece of aluminum angle stock forms the base for the windex.
Although we did not do it, a previous owner did. The hole was drilled and tapped as others have indicated here. We were planning to add a windex anyway because we couldn't see it from the deck. When we took the mast down to add a furler we found the threaded base of the previous windex left in the masthead so changing it out was a simple process. Although I won't say who forgot to put the anti-bird spike on the top before raising the mast.
Regarding the anti-bird spikes, a day after I launched a year or two ago, some sort of large bird perched on my SS windex mounting arm and bent it resulting in my windex pointing straight up. You'd think I would of learned a lesson and installed some anti-bird spikes, but I need to be hit on the head more than once to get the hint.
Thanks for all the great recommendations. It's remarkable how much experience and knowledge is reflected in these discussion threads. I'll try the masthead drill and tap.
Remember that you are drilling into aluminium so you need to use course threads. If you use fine threads with aluminium, they will pull out the first time you to tight...that being beyond the torqe spects for the bolt you are using. I would estimate that 97 percent of all hand tightened bolts or nuts are tightened beyond torqe spec. Other than that, use blue loc-tite. Cheers.
