 where can I get one of these?
new sailor
Initially Posted - 08/13/2006 :  10:46:33  Show Profile  Visit new sailor's Homepage
Catalina Direct doesn't show this part on thier site. Where else might a look to order a couple of these things? I think they are called turn buckles.
Former owner of a 1989 C25 WK/SR #5862
Clear Lake, TX (near Houston)
http://www.myspace.com/a_boat_called_lafawnduh
Response Posted - 08/13/2006 :  12:13:06  Show Profile
I think it's called an ugly sheave... If you haven't done it yet, you should have Catalina Direct send you their C-25 Handbook, which is much more complete and informative than their site. It used to be $10... might be more now, but well worth it, even if it is primarily a catalog. They send out free annual updates.
Meanwhile, call them--they'll tell you if they have something like a "mast exit block". (I gave my handbook to the buyers of Passage.) Another option would be to remove the four screws, take apart the little block, and replace just the plastic sheave (the broken part).
PS: A turnbuckle is the adjuster at the bottom of each stay.
Edited by - Dave Bristle on 08/13/2006 12:18:26
Response Posted - 08/13/2006 :  13:01:35  Show Profile  Visit britinusa's Homepage
I would remove it and look for the manufacturers name. Then do a search on that.
There are plenty of plastic sheves to be found around the net. I would expect it will cost you about $5.00 to fix it. If you are near a marine fleamarket, I would head there with the sheve in hand. If the sheve is 'riveted' in place, then you could replace the rivet with suitable pin peened over.
Admin
Forum Admin
Response Posted - 08/13/2006 :  13:23:03  Show Profile  Visit Admin's Homepage
Sheaves are sometimes difficult to get exact replacements for and it is easier to replace the entire piece.
Check with Harken, WestMarine, Catalina Direct etc.
Lightnup
Response Posted - 08/13/2006 :  19:02:01  Show Profile
They are called exit blocks...
[url="http://www.catalinadirect.com/index.cfm?fuseaction=product.display&Product_ID=316"]Catalina Direct Exit Block[/url]
Steve
ilnadi
Response Posted - 08/13/2006 :  20:58:47  Show Profile
We replaced ours (that looked just like the picture) with the ones Steve pointed out. We do have 5/16" halyards but it works fine. The Harken exit blocks look nicer (and rated for 5/16") but Harken service gave the cutout dimensions as follows and they are all too wide for the C25. We did not want to widen the hole.
088 3/4 x 1 3/4
287 3/4 x 1 3/4
131 15/16 x 2 3/16
Douglas
Response Posted - 08/13/2006 :  21:25:51  Show Profile  Visit Douglas's Homepage
Try Catalina direct www.catalinadirect.com
new sailor
Response Posted - 08/13/2006 :  22:05:12  Show Profile  Visit new sailor's Homepage
Thanks y'all. I just ordered two of 'em from Catalina Direct. $24 each. The new ones have sheaves made of aluminum instead of plastic which should hold up better.
Edited by - new sailor on 08/13/2006 22:07:14
pegasus
Response Posted - 08/14/2006 :  10:43:47  Show Profile
I had a problem with a previous reply so this may be a duplicate post, but try Garhauer Marine http://garhauermarine.com/ I replaced some turning block sheaves for just a few bucks.
Alan Clark
Response Posted - 08/14/2006 :  13:45:10  Show Profile
Thanks for the picture, I was looking at it and noticed what I think is your boom vang with the block near your deck. If it is your boom vang try turning it so that the release is attached to the boom up higher, It is MUCH easier to release than when it is close to the deck .
Response Posted - 08/14/2006 :  13:52:00  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Alan Clark</i>
<br />Thanks for the picture, I was looking at it and noticed what I think is your boom vang with the block near your deck. If it is your boom vang try turning it so that the release is attached to the boom up higher, It is MUCH easier to release than when it is close to the deck .<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
Good tip!
I did that myself last year...It is much easier to adjust when the fiddle/cam is on the boom.
dblitz
Response Posted - 08/17/2006 :  08:12:47  Show Profile
I guess I'll get my answer when I take the mast down in the fall, but I want to ask, are the masthead sheaves made of the same material as the exit block shown above?? I'm in the process of locating a replacement for my exit blocks, my deck organizer sheaves all had to be replaced and I notice that all the sheaves on my traveler/split backstay are disintegrating. So the only sheaves to worry about are the ones up the mast that I can't see. Were they made with some other more UV resistant material??
Response Posted - 08/17/2006 :  21:53:39  Show Profile  Visit Frank Hopper's Homepage
Daniel, the UV has eaten all of your sheaves. Yes your mast heads will need to be replaced. As for the traveler, if it is the old style rod traveler then Harken has ball bearing sheaves, if it is the new X track traveler then you need a new car.
