Does anybody know what 50% of a battery is ? or when you should start chargeing From what I read , you do not want use your battery past 50%. is that 6 volts ? or higher(I would think higher)
I also read dont go bellow 12.2 volts, for best battery life . That sounds a little too high though . I usealy go between 12.4 , down to 11.4 on 24 hr use .
Also I have agm battery I think group 24 , the readings are off the gps .
Whats too much charge ? when the battery is full I could charge 14.4 my motor has a 10 amp charger. my old motor had a 8 amp charger , I always thought that wasnt enough it would charge 13.4 at best.
Sean, The best way to tell the state of your batteries is with a hydrometer. For your 12 volt battery, a good charge will have a specific gravity (density of the electrolyte) of 1.27, and a voltage of 12.75 VDC. A battery that has been discharged to half of it's capacity will have a specific gravity of about 1.17 and a voltage of about 12.1 volts. If you're discharging down close to 11 volts, you are approaching a dead battery, and almost certainly causing the battery harm.
And no, I'm not the David who wrote the latter article. However, I was an electrician in the USN for five years. I spent lots of time checking specific gravities on LOTS of batteries. One of the uninterruptable power supplies I worked on had 138 2 volt cells, each one about the size of a large suitcase stood on edge. Checking all of those cells was a chore, and we did it twice a month.
Both of these articles have lots of good information in them, probably more than you want to know.
Here is a useful table from an Interstate Batteries booklet entitled "Marine/RV Battery Maintenance." It shows you interesting things at a glance such as the small voltage range between fully charged and completely discharged for a 12V battery.
