 Rail Mounted Gas Cans
jesse camp
Initially Posted - 05/03/2006 :  09:17:39  Show Profile
I wanted to increase my fuel and water capacity by mounting a 1x4 x 66 inch wooden plank between the first and second port stantions attached with SST u-bolts and lash one water and two mil type plastic gas cans. Any suggestions or problems for anyone who has done this before? I will be taking a week trip on the ICW south of Cape Canaveral, Fl and wanted to stay away from marinas as much as possible. Thanks.
Jesse Camp
Sea Trekker
87 5550 SK SR
Merritt Island, Fl
Jesse Camp
JimB517
Response Posted - 05/03/2006 :  12:52:00  Show Profile  Visit JimB517's Homepage
I carry 15 gallons of fuel without doing that - a 7 gallon tank on the shelf in the lazerette, a 3.5 gallon tank on the floor in the lazerette, and a 5 gallon gas can under the V Berth. I save 1 gallon juice bottles to carry extra water. I carry about 10 to 12 gallons, a good place is under the quarter berth, also that little shelf in the V berth. Plus the water tank holds 15 gallons. I could easily carry another 5 gallons of gas under the v berth giving a total of 20 gas, 25 - 30 water. That's enough for 2 to 3 weeks and travel of 500 miles or more.
When I drain melt water out of the cooler, I put it into the solar shower.
Personally I think the side decks are narrow enough without adding tankage up there. Want to keep the weight down low and centered, like I do.
Keeping ice is the hardest thing on a long voyage.
Got your solar panels?
jesse camp
Response Posted - 05/03/2006 :  13:36:59  Show Profile
Do you think it is safe putting fuel tanks in the V-berth. I note a
leak in either the lazzarett (the big one on the port side) or the V-berth could leak into the bilge. The fuel locker lazzarett is good for fuel because it does not vent or leak into the boat.
Water is another thing. Thanks
jesse camp
Response Posted - 05/03/2006 :  13:46:43  Show Profile
Oops! Yes I mounted a 12 x 24 inch Siemens Panel on the starboard rail. I used the plastic clamps that swivel to follow the sun. The PO had mounted on the stern which was in the way. I dont use the ice box for a cooler, but I use as a food locker. I bought a 55 qt 5 day ice chest from Walmart and freeze a gallon milk jug with water as well as a plastic water container from Walmart that is about 2 inches thick by 18 inches x 10 inches, both last quite a while and then drink the water when they melt. I got a sun shower from Campmor but I have not tried it yet.
Response Posted - 05/03/2006 :  17:25:30  Show Profile
When cruising, in addition to my 6 gallon fuel tank, I carry two 5 gallon Blitz gas cans (Walmart $5-6) and store them side-by-side on the aft cockpit floor. In this location they are out of the way when sailing and readily accesible when I need to refuel. The size of the cans are such that they snuggly fit yet are not wedged in place. I place a white kitchen garbage over each (the bag is upside down) to shield the cans from the sun and weather.
Gloss
Response Posted - 05/03/2006 :  19:58:59  Show Profile
Last year two of us members of fleet 89 each sailed our boats to the Dry Tortugas (We actually had three fleet 89 members on two boats). Dwight set up his two jerry cans of gas onto a stanchion mounted 1 x 4 just like you are proposing. It seemed to work out just fine. We noticed that there was some rubbing of the can on the base of the stanchion, so we moved the cans a little.
I put two 6 gallon gas tanks down into my lazarette, each wrapped into plastic bags. I could still smell a slight whiff of gas, and I didn't like that at all.
One of my future projects is to mount an inboard 12 gallon permanent tank somewhere below.
But of course I'll win the powerball tonight so it will be a moot point as I'll be buying a bigger cruiser
jesse camp
Response Posted - 05/04/2006 :  07:07:15  Show Profile
Thanks for the comments, I will go ahead and mount my 1x4x66, I bought a piece of Douglas Fir, oak was too stiff. I will sand and varnish and polyurethane the piece and use u-bolts with lock washers.
It looks like I can mount each can between the shrouds. The white garbage bag is a good idea for gas in the cockpit. I know the sun really expands the cans in the middle of the day.
Best Regards,
Jesse Camp
87 5550 SK SR
Sea Trekker
Merritt Island, Fl
DGuinn
Response Posted - 05/04/2006 :  10:40:24  Show Profile
Jesse
You could just lash the 1X to the stanchions.
Less hardware to bite you.
Lightnup
Response Posted - 05/05/2006 :  01:29:39  Show Profile
Jesse brings up a question that I've often wondered about. When those plastic gas containers are onboard and are going to be in direct sunlight - such as lashed to stanchions - do you leave them tightly closed to eliminate spills and fumes or do you crack the cap just a bit to eliminate pressure buildup, tank expansion and possible rupture or explosion?
Steve
