 Can I make 10kts with sails and motor?
djn
Initially Posted - 04/20/2006 :  09:48:11  Show Profile
Hi All, I was just thinking about the dynamics of sailing and wondered if I was making 5kts with my sails set wing on wing, then dropped my motor and went to 3/4 thottle, would the boat do 10kts? Or would I make 6kts and burn up gas? Cheers.
Dennis
No Boat
S.E. Michigan
Response Posted - 04/20/2006 :  10:05:15  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by djn</i>
<br />Can I make 10kts with sails and motor? <hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
Not unless your are also being pushed by either hurricane winds, a tsunami, or down Niagra falls!
Without the assistance of some outside force, the displacement hull of the C25 will not get much over 6.5. (Although I did do 8.4kts once downwind in a wicked blow!)
You will probably get 10kts SOG on your trip down from Port Huron though.
Edited by - dlucier on 04/20/2006 10:17:11
existentialsailor
Response Posted - 04/20/2006 :  10:10:04  Show Profile
No, you need a Capri to be able to do 10 kts, and that is without the motor!
Ericson33
Response Posted - 04/20/2006 :  10:22:21  Show Profile  Visit Ericson33's Homepage
Yep, Nothing like passing the fleet downwind, with the tiller humming, and the other boats complaining about the wake we are throwing
Response Posted - 04/20/2006 :  10:26:39  Show Profile  Visit Champipple's Homepage
Sure - what kind of knots are you thinking about....
Bowline, half hitches, reef knots...Sheep shank, that's a real good one.
There are very few instances where you will get major benefit from Motor sailing. None of them will register a speed higher than hull speed...
JimB517
Response Posted - 04/20/2006 :  12:12:12  Show Profile  Visit JimB517's Homepage
I've seen 9 knots for a short time under spinnaker in strong winds while surfing down 6 foot waves. That's the only way its going to get over 6.5 - when wave action is cancelling out the natural hull wave.
Watch closely, keel sailboats and other displacement craft are sitting in a wave of their own hull length. It gets nearly impossible to climb out of this wave - you needs lots of power to push the bow up and over it. When that occurs, it is called planing. Flat bottom power boats do it and some sailing race boats with very flat bottoms and very deep narrow fin keels.
johnsonp
Response Posted - 04/20/2006 :  14:05:55  Show Profile
<font color="blue"><font size="4"><font face="Comic Sans MS">With the tide and the current.
SOG 8 knots
paulj C250 WK #719</font id="Comic Sans MS"></font id="size4"></font id="blue">
existentialsailor
Response Posted - 04/20/2006 :  15:26:45  Show Profile
Jim,
You mean a flat bottom and keel like this?
Ericson33
Response Posted - 04/20/2006 :  16:21:43  Show Profile  Visit Ericson33's Homepage
I was reading a year ago on the Sj24 sire a couple of engineers talking about this, the faster you go the more the hull is sucked down into the water.
Rick the boat looks really smooth
Brooke Willson
Response Posted - 04/20/2006 :  16:42:09  Show Profile
I've done 6.7 knots indicated on the GPS on a beam reach -- but the tide was probably giving me a knot or more. So, yes, you can do 10 knots if you have a 4 knot current/tide.
Remember Dennis, in a powerboat you get there quicker. In a sailboat, you're already there.
Brooke
djn
Response Posted - 04/20/2006 :  17:13:15  Show Profile
Hi Brooke, I am not really concerned about the speed, it was just a theroetical thought.
Hi Don, yep, the St Clair river is running at about eight kts so I should see some come speed over the ground. When the boat was taken up to that marine, they spent six hours pushing through the current. Cheers.
existentialsailor
Response Posted - 04/20/2006 :  17:22:06  Show Profile
Chris,
That's the barrier coat before I put VC17 on. That was last spring, I'm worrking on a few spots I wasn't satisfied with this spring as well as having eliminated the thru hull for the sink. If I can get a puck transducer to work this summer, next spring I'll eliminate the protrusions for the depth sounder and the knot meter.
Captain Bill
Response Posted - 04/20/2006 :  19:05:11  Show Profile
Dennis,
When we were bringing the "Mary Joyce" home after purchase we had a good wind from starboard and the Honda 9.9 going almost full blast trying to get in before dark. The wind was from the starboard rear and we had small waves in the Pamilco. Our GPS constantly measured 6.9 to 7.1 depending where we were on wave.
Bill
Gloss
Response Posted - 04/20/2006 :  19:33:08  Show Profile
so what is the hull speed for the Capri?
Response Posted - 04/20/2006 :  21:14:40  Show Profile  Visit britinusa's Homepage
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Hi All, I was just thinking about the dynamics of sailing and wondered if I was making 5kts with my sails set wing on wing, then dropped my motor and went to 3/4 thottle, would the boat do 10kts? Or would I make 6kts and burn up gas? Cheers.<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
Dennis,
Wing on Wing (Goose wing to some) means you are running from the wind, not the fastest point of sailing (The max speed if the boat was capable, would be the wind speed) As you approached wind speed, then the power to the sails drops (Imagine if you were powering along at 10knots (SOG) from a 5knot wind, your sails would be backing!)
Ericson33
Response Posted - 04/20/2006 :  21:25:34  Show Profile  Visit Ericson33's Homepage
<br />so what is the hull speed for the Capri?
Hull speed by the numbers is 5.8 knts, I have seen 8 knots with just the main sail up in 35 knot winds going dead down wind. My knot meter was off last year when we sailed the MS Regatta, but I have never felt a sailboat set up and take off like we did. LOOK at this
Here is the link to the post
http://www.catalina-capri-25s.org/forum/topic.asp?TOPIC_ID=10603
JimB517
Response Posted - 04/20/2006 :  23:41:36  Show Profile  Visit JimB517's Homepage
Yes, Capri25, like that, or, like this
WIndquest, at PHRF -235, the fastest boat currently entered in Newport-Ensenada. Indiscipline, at 228, is the slowest.
oldsalt
Response Posted - 04/22/2006 :  09:51:21  Show Profile
Once while sailing against the tide in the narrows under the Verrazano Bridge between the upper and lower bays in New York Harbor, I was making a good 5 Knots on the knot meter and Silver Girl had a really nice "bone in her teeth".
Problem was; I was actually sailing "backwards" and losing ground against some familiar landmarks.
If I was sailing in the other direction it would appear that I was far exceeding hull speed by GPS, but not speed through the water.
So, the answer is yes, I believe you could exceed 10 knots over the bottom, but not through the water.
Response Posted - 04/24/2006 :  11:41:10  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Capri25</i>
<br />I was reading a year ago on the Sj24 site a couple of engineers talking about this, the faster you go the more the hull is sucked down into the water.
Hmmm... That's one theory, I guess. The explanation I buy is essentially what Jim B. described: There's a speed at which the size, period, and angle of the bow wave makes the peak-to-peak wavelength, relative to the hull's direction, the same as the boat's LWL, and the boat is "caught" between the too peaks unless it has enough power to climb over the peak. The boat can't push through--the wave will grow and push back as hard as the boat is pushing against it, so the boat has to be able to at least becoming "semi-displacement" (bow up).
I encountered a tug one day that was apparently stuck at hull speed but was applying much more power than needed to be there. You could see that the bow wave had simply grown almost big enough to wash over his deck, and was extremely vertical. A few hundred yards away, Passage went airborne off the first peak, did about a 4' free-fall, and crashed into the second peak, with water going over our bow and cabintop. Fortunately when I saw what was coming, I had my passenger close down the forward hatch which we had left open on that windless day. There were probably some grins on the tug...
Charlie Vick
Response Posted - 04/24/2006 :  20:22:41  Show Profile
Hit 8.4 according to gps down wind, wing on wing, (not on purpose!) by myself in 35-40kts of wind.
Scared me to death. I kept wondering how I was going to come about and get the sails down without flipping her. Had the jib to port so thats the way I turned, back up into the wind. Worked out great but I don't ever want to be in that situation again.
To go go ten k with sails up and on the iron genny I think you would need a Mac with a 50 horse motor and, we know you don't want that.
