 Factory Marine Head
Tradewind
Initially Posted - 03/12/2006 :  17:47:18  Show Profile
For a factory installed marine head, where is the holding tank installed and what size?
1998 250WK #331
CILCIA
Steve
Pensacola, FL
River Harley
Response Posted - 03/12/2006 :  18:19:41  Show Profile
Ours was installed behind the aft berth in the compartment where the batteries are located. I don't recall the size, but it's a lot larger than a porta-potti.
River
Tradewind
Response Posted - 03/13/2006 :  08:49:21  Show Profile
Thanks River. That's where I'll probably install mine.
frog0911
Response Posted - 03/13/2006 :  09:31:05  Show Profile
Steve, my holding tank from the factory is 17 gallons and is located behind the aft-berth bulkhead port side. All the plumbing runs along the port side in the small race-way. If you would like to see some pictures let me know.
Tradewind
Response Posted - 03/13/2006 :  12:16:51  Show Profile
Frog, would love to see the pics, might make my installation easier. I'm wondering if I can get a 17 gallon tank thru that small opening in that bulkhead. I may have to settle for a smaller tank.
You can email me at dscarey1631@hotmail.com
Edited by - Tradewind on 03/13/2006 12:18:32
frog0911
Response Posted - 03/13/2006 :  18:33:41  Show Profile
Steve, first you don't put the tank through the battery check opening. You remove the bulkhead completely by removing the port side panel in the aft-berth, then remove the screws from the rear bulkhead and remove it. You will find there is tons of room behind it. I don't have a picture of the head itself, but it occupies the same space that the porta-pottie does. If you need more detail let me know and I will get more pictures.
The wet locker behind the head. The tubes that go up are the vacuum loop. The others go through the locker along the port raceway to the rear of the boat.
The tank front showing the hoses that come along the raceway out to the tank. The tank itself.
Edited by - frog0911 on 03/13/2006 18:43:15
Tradewind
Response Posted - 03/13/2006 :  21:06:17  Show Profile
Frog, thanks, that's what I need. Looks easy enough. Don't need a pic of the head itself, I have the head already. I just need to get back there, measure for the tank and find a way to support and brace it.
SEAN
Response Posted - 04/05/2006 :  18:51:04  Show Profile
Hey jerry
Do you think your head is 17 gallons .
I have a factory head I thought it might be about
9 gallons its 12" high almost square i foget the rest .
640wk
frog0911
Response Posted - 04/05/2006 :  22:58:03  Show Profile
I have not measured the tank, but the manual that came with my marine head says it is 17 gallons. Next time I take the rear bulkhead out I will try and remember to measure it. Don't hold your breath though, us older folks do have some memory loss at times.
SEAN
Response Posted - 04/07/2006 :  08:36:19  Show Profile
thanks ,
I was thinking if I had to switch it I would try to go bigger .
I m not sure what size mine is either
Tradewind
Response Posted - 04/07/2006 :  09:51:52  Show Profile
Thanks for the info. I'll pull that back bulkhead out and take some measurements. Guess I'll have to glass in a shelf back there.
americanrascal
Response Posted - 04/07/2006 :  20:24:24  Show Profile
Steve- I'll be around at the dock Sat afternoon and Sunday afternoon if your down and want to see mine
Joe
Tradewind
Response Posted - 04/08/2006 :  11:35:43  Show Profile
Joe, I'm working this weekend but plan to get down there next week and launch. Will you be around? I'm sure I'll need some advice on raising the mast for the first time.
americanrascal
Response Posted - 04/09/2006 :  08:47:16  Show Profile
Steve:
Plans are now for us to be down that way next Saturday and Sun. and will be glad to help launch and raise mast. Email me a time. I think Earl is relaunching then too as he's back in service. Sorry you'll miss todays race. Will email you if things change.
Joe
