I have installed self tailing Harkin winches on the coaming box, but would like to know if anyone has a suggestion as to what angle to place the stripping arm. I currently have mine set at approx. the 8 o'clock position (bow being 12).
I recommend it be straight toward the user. If you're going to be positioned a little aft of it, inside the cockpit when using it then the location you described sounds just right. Nice to have, aren't they?
Second that recommendation by Bubba. I have a wheel and the crew handling sheets is located in the cockpit just in front of the wheel with the arm pointing directly toward them, about 10 o'clock (starboard) and 2 o'clock (port), otherwise it sounds like you have them set correctly.
Ya know, I was only visualizing the starboard winch when you mentioned the eight o'clock position. You'd want to mirror that on the port side. So I should just leave it at "facing the user" wherever that person is going to be. That position may be different depending on whether you have a wheel or tiller and whether you'll be single-handing a lot or normally have crew. What ever you do, those self-tailing winches will be great to have!
they are great. I took the idea from Arlyn and mounted them on the coaming box so that I can do all the work and not have to bother the "Captain", if you know what I mean. Sorry about the confusion, the Port winch is at @ 4 o'clock and the starboard is 8
Do you have any pictures of your installation? What did the winches cost? How do you route the sheets? Do the sheets interfere with either the safety wires or shrouds?
I ran my sheets almost identical to Bryans. The only difference is I used different routing blocks and my winches are set aft just a bit. They dont interfere with any other lines. I bought them at West Marine and I think they were $765 for the pair.. I dont have a picture of the sheet routing but will take some later today. It appears that Bryans winch arm is about the 9 o'clock position.
