So this year I had 2 close calls (Already) when maneuvering in close spaces, one was a 3 point turn that I just could not get the bow around. The other backing out of the slip (Wind). I have wheel steering and a mew 9.9 Mercury with binnacle mounted Edson controls. I am ready for a Hard or Soft link. How dramatic of an improvement is made? Ready to try the soft link.
Any thoughts?
Mac's Bounty 2003 C250 WK #679 Orient Harbor, NY
If you think you can, or think you can't, pretty soon you find out your are right! H.F.
When I had the hard link on my old 2-stroke engine, I really liked it, it made it really easy to maneuver in and out of the marina. My new(er) Tohatsu 4-stroke required a scissors extension, and making a viable hard link has evaded me after several tries. I also tried using Arlyn's soft link, but that didn't work so well either. I now just adjust the angle of the outboard by it's tiller handle if I need to. It's nowhere near as convenient, but I've gotten used to it.
If you're experiencing maneuvering problems at low speed, I can vouch for the efficacy of a hard link, and I'm sure others will vouch for the soft link. To directly answer your question, there's a dramatic difference to be had when your outboard swings in concert with your rudder (at low speed).
David C-250 Mainsheet Editor
Parts were made by Stearns for a kicker motor on fishing boats and modified for my use. Last I saw, it was no longer being sold under the Stearns label, but might be available under different brand names:
Nice to see that you can get them again. Stearns appeared to have discontinued them for a few years, and friends couldn't find them. Panther appears to be a different brand name for the same parent company, so it should be exactly the same thing. For anyone interested, there are several variants of this listed on Amazon:
By coincidence, I was in WestMarine yesterday and saw that they had the zinc coated version in stock. The SS version costs about double, and was available as the "saltwater" version on the WalMart website that I linked above.
In my design, I also made use of some 1" aluminum angle iron, and a few screws and nylon washers to fabricate the bracket at the top of the rudder. Also, you can see in my linked pictures that the outboard does not turn at the exact same angle as the rudder -- it turns a little less. Getting them to turn at the exact same angle would have required a much longer extension arm back from the rudder, which I thought would increase stress on the rudder. Also, that would have limited the movement of the rudder to match the motor's turning limitations. I found that even though the motor and rudder weren't perfectly parallel when turning, the maneuverability of the boat was still significantly enhanced.
All done, Really the project went very well, no lost parts or tools. The link is of a very high quality. I have not tested it as of yet. Need to add some foam on the link like you did. This with binnacle mounted controls should make a huge improvement.
Thanks for your help and advise.
