My uppers are larger than my lowers... Well lemme rephrase that, the wire is larger, so I assume the turnbuckles are different sizes.
I want to change ALL my turnbuckles out to open style and DITCH the locking nuts... I am beyond frustrated with these closed style turnbuckles (this is my first year struggling with them, not sure why I had such a hard time this year as opposed to last year)...
I just verified my LOWER was a 5/16 LH turnbuckle. Are the uppers the next size up?
One thing to also think about is most closed body turn buckles don't have a hole through the stud that you can run a cotter ring or pin through to keep the rig from loosening its self on the leeward side of the boat. On some boats you can pin two turn buckles together but because of how far apart the turn buckles are on the capri I don't think that would work. The two options I was given by my rigger was to either put two nuts on the stud about an inch a part to hold the stud in a drill press while you make a hole in the stud, then unscrew the nuts fixing any bad threads, or replace the standing rigging which I did because I didn't know the age of the rigging.
My boat has the same gage shrouds on both the uppers and lowers. (the smaller size) I've always wondered if that was a characteristic of the early hulls or if somebody was hung over on a Monday when they made the cap shrouds. I was just thinking about it last weekend when I was watching them get battered around while I was way overpowered with a 155 up.
Oh, just purchased 1 open turnbuckle, and the velcro with the pins... I changed out from the closed turnbuckle... I wanted to make sure I like it! BOY DO I LIKE IT! Why in God's earth did I not do this long ago? This turnbuckle:
This velcro... remember to remove the locking nuts, you don't need them if you use the velcro (makes quick rigging changes way easier).
