Well, the deck organizers I ordered from Catalina Direct will not fit my Catalina 250 1997 WK without drilling new holes and filling old ones. However, the double cheek block that works to turn two lines now could easily be made into a triple cheek block that would allow me to run the three lines back that I need to, WITHOUT drilling new holes. The profile would be about 5/8" thicker than the double cheek block. I don't like it, but I think it will work fine and will not require anything but a little longer bolt. Does anyone see any problems with going from the current double tall cheek block to a triple other than being a bit taller to kick on your way up to the anchor?
MJ, Filling the old holes and drilling new ones is less work than you might think. I have a double high turning block on my port side, and I don't like it. But, I only have two lines that run back there, so it hasn't irritated me enough to make me replace it. What I worry about is having a trip hazard on the cabin roof. I tend to go up and down the starboard side for some reason, so I'm usually stepping over my single height triple block, which isn't high enough to catch a toe effectively, especially if you're shuffling, which is what I try to do.
If you decide to go the triple high route, I might be interested in purchasing one of your new triples you're not going to use. However, I recommend biting the bullet and filling the old holes, overdrilling the new ones, back filling with epoxy, and then drilling through the epoxy to mount the new ones.
MJ, only problem I can see is the problem of tripping over it. It shouldn't be a problem filling the holes, though.
I'm going to add a triple rope clutch starboard and trying to decide to go with a single level triple organizer or the stack, I'm leaning toward the single level to minimize tripping over it.
David, what brand is your single level triple and where did you get it?
Frog has some good pics on the other topic started by MJ, that's what I hope to do.
Steve, I think mine is made by Garhauer, I didn't install it originally, but I had to remount it because the PO put it too close to the starboard rail, you couldn't move anything past it in either direction. Plus, they didn't overdrill & epoxy, they just drilled holes and went for it. So, inevitably, they leaked as well. That's all been fixed, I removed it (actually them, because the double stack on the port side was in the same condition), overdrilled the original holes (on the starboard side, way over drilled them because I had to move all the holes about 1/4"), backfilled with epoxy & then drilled the mounting holes. Inside the cabin I left the holes a little dimpled in so I could fill with Marine Tex (white), just so it looked better.
I don't think Garhauer makes my exact model any more. For all I know it was installed back in '97 when the boat was brand new. I searched their site a while back to see if I could find another matching one for the port side, but wasn't able to.
I've filled and drilled before and since the current double-stack is in the diamond pattern, I think that's a recipe for trouble to fill and get a good finish. My thinking is that on both sides of the deck there are cabin top winches, jib sheet blocks, rope clutches, and a lot of line running back to cockpit. In this case, I don't see how adding another 5/8" thickness for a triple stack is going to increase my odds of tripping, especially since adding it and bringing all lines to cockpit I won't be on deck nearly as often. My only concern is that by adding an additional cheek block on top, you increase the moment arm and therefore I may need to add larger fender washers to back it all inside the cabin top.
