The PO of my new to me boat took a 2" gash of lead out of the bottom of the keel, aft edge, when backing it off the trailer. I'll see if I can post a pic of it later. Basically, how should I go about fixing?
I've thought of bondo and melting lead/repainting but not sure if any of you have had a similar issue.
For a gash that small you definitely do not want to hassle with hazardous molten lead. Just fair it with a cosmetic patch like Randy suggested.
Randy - Marine-tex seems to be the most popular fairing compound out there. I have a couple of small things I need to do above the waterline. How does Marine-tex fare with UV exposure? Typically epoxy needs to be painted over, and that would make it difficult to match with unpainted gel coat. Does Marine-tex have pigment or other UV inhibitors built-in, or does it need to be painted?
Rick, you'll want to cover it with something--it's basically heavily thickened, putty-like epoxy, slightly gray. I've used one-part gelcoat patch in a little tube (from WM). I applied a couple of coats so it was above the level of the surrounding gelcoat, and then sanded it down. I don't think Bruce Ross (C.O.) could find it--I might not be able to, either. You have the advantage of a bright white hull--it should be easy. But leave the Marine Tex a little "low" so you can sand the gelcoat to the level of the surrounding surface. For small enough dings and gouges, the gelcoat alone might do the job.
I have not had issues with MarineTex yellowing. Personally I would not bother with gelcoat on the keel. The Marine Tex will be sufficient. Use the white version, not the gray.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Nautiduck</i> <br />...Personally I would not bother with gelcoat on the keel. The Marine Tex will be sufficient...<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">I agree. But regarding Rick's boo-boos, gelcoat will make a nicer visible surface.
Will: Looking at your pix again, I'd use a nail or a drill and make some shallow holes in the lead before packing in the Marine Tex. That'll help it hold in place.
I have also had damage to my keel from the trailer, look up the topic 'WK Trailer Issues, (help)' sourced by me (moserd); maybe it will help. My damage was repaired with epoxy and fiberglass cloth.
I was so busy with dropping and raising the mast yesterday that I forgot to take pictures :/ I learned some valuable lessons though; put the anchor light and windex in when the mast is down the first time...and tie a messenger line to the furler halyard tail.
I'll take a picture this weekend before I put her in the water!
