My boat came with an asym with a sock. Ive used it a few times. i ran the control lines through a double block at a stanchion base back to the cockpit. I bought a symmetrical spin without a sock on ebay and saw that the sock on a boat of this size is a waste of time. the spinnaker is really not that large, and the control lines just add complexity.
1. 35' of control line worked out to be just about right.
2. Wrapping the control line around one of the halyard cleats on the mast worked out better than trying to tie it to the spinnaker pole ring.
3. Inside jibe works great by dousing, jibing, deploying. Just make sure the jib halyard is brought back and clipped onto the spinnaker pole ring.
Note on Dousing: If the wind is strong, it will be difficult to pull the sock down without luffing the sail a bit.
The spinnaker is a cruising asym with 31' luff. I tacked it 18" above the stem fitting. The tack of the spinnaker hanked onto the forestay and I ran the tack line to a bow cleat.
With just the spinnaker flying, we were able to make about 5.5 kts in 9 kts of wind up to about 110 deg TWA.
Because I wanted to leave the genoa hanked on to the forestay and because I was doing an inside jibe, I had to tack the spinnaker to the forestay above all the genoa hanks. If I did an outside jibe (need to install the spinnaker crane) I could tack the spinnaker about a foot lower and probably point up to 100 TWA.
What didn't go so well: I used vectran for the first time. I used it to attach the spin blocks to the stern cleats, to attach the spinnaker head to the becket on the sock control line block, and to attach the clew to the spin sheets. I tied a bowline in the vectran to make these attachments. One at a time, each of these tie points either broke or the knot slipped. I'm guessing the knot slipped. I re-tied each of the points as they broke by doubling up the vectran and using a square knot, they never let loose again. Need to research proper knots for vectran, best and most effective ways of whipping it, and probably need to make some soft shackles out of it.
