Has anyone encountered any leaks coming from the anchor locker area ? Thanks to the torrential downpours of the last few weeks I have found a leak coming in thru the bow area and underneath the v berth . Any tips on the best way to deal with it on the water ? I did take a pic of the suspect area but not yet figured out how to post.
Have you checked the drain hole to make sure it is not blocked? I used a phillips head screw driver to ream it out periodically. Bugs like to build a dirt nest in there.
DavidP 1975 C-22 SK #5459 "Shadowfax" Fleet 52 PO of 1984 C-25 SK/TR #4142 "Recess" Percy Priest Yacht Club, Hamilton Creek Marina, Nashville, TN
Yeah it's clear , thanks , there's a some cracked gel coat on each side of drain holethought it may be seeping thru there . I took a pic today how would I post it here ?
Mine leaked and finally traced it to the seam between hull and liner. Especially in bow light holes. I have ground any loose stuff and any paint that I could get to then used a lot of west system in the caulking gun tube. That was much easier than mixing thickener in the thin epoxy. I then gave it 2 coats of thin epoxy over all surfaces. I also did the drain tube as per Frank Hopper at the same time. Will be giving it the final test down here in Cape Coral this week. Before I made these repairs I could run a hose in the anchor locker and it never filled to over flowing even with drain tube plugged. All went in the bow under V-birth.
Wesley Allen "Breaking Wind" 1982 C-25 SR/TR/SK #2773 Hemlock, MI
So did you seal the seam between hull and locker from inside / underneath ? Mine seems to be leaking from the very point of the bow which would be inline with where the nav lights come in . I'm in the situation where it would be a wet repair until fall .i wonder if 3m 5200 would repair it I've read being polyurethane it cures with moisture or if I'd be creating a bigger mess .
All of the seam repair was done inside the anchor locker. but yes I removed the bow lights because there is a seam between liner and hull there also. That seam was a major leak spot on my boat.
Mine leaked when I first got the boat. I cleaned it, sanded it, applied a layer of glass and resin with double layers at joints. After cured I painted with bed liner. So far mo more leaks. I do have to run a wire up the drain tube occasionally.
1988 WK/SR w/inboard diesel Joe Pool Lake Hobie 18 Lake Worth
I'm thinking that will be the solution and probably installing larger drain tube . Everything is so wet at and will be for several weeks ,the repair will have to wait.
After the repairs that I did in the anchor locker that I previously described I am very happy to say that after three days of crashing through the waves in front of Ft Myers Beach that the bow area is bone dry.
