I picked up my sails today from the sail loft and as it turns out the main sails foot length is actually shorter than stock by about an inch. So back at the boat, I measured my boom. My owners manual says the boom should be 10'3". My boom measures 9'7". 8 inches shorter. Though I didn't actually bad mouth Yager Sails, I did come close so my apologies to Yager. My guess is that one of the POs shortened it because they had also changed it to mid boom sheeting. Wanting the boat stock, I removed it and returned it to boom end sheeting. So, is the short boom going to cause me any problems other than my original out haul problem ? Thanks for your thoughts.
When I received my new main from Doyle Sails in Detroit it also was a tad shorter than my original. But alas my old sail is stretched a bit. Still a lot better sailing with the new sail. IMHO your boom shortened should not be a problem with your main sheet location as it is.
Wesley Allen "Breaking Wind" 1982 C-25 SR/TR/SK #2773 Hemlock, MI
Well actually the stock boom length for both tall and standard is 10'4" This is for the extrusion only not counting the end cap or gooseneck cap. If your extrusion length is 9'7" then the PO must have cut it down and this is why your mainsail foot takes up all of the boom and leaves you with only enough room to tie it off to the end cap and no room to put in an outhaul. The standard foot of the main is 9.58", Tall or standard. Is your main sail foot that length or close? Next is to measure the luff. Standard is 24.66 and Tall is 27.66. If your luff is one of those measurements than I would say you have a standard sized mainsail and it is not custom. Can't blame the sailmaker for making a standard sized sail. I would guess the PO cut the boom, Moved the traveler and possibly moved the boom up to gain headroom and space in the cockpit. Maybe for a Bimini? The only problem I can see is you wont have an outhaul. This is not a bad thing if the sail is a boltrope foot. The other problem is with the shorter boom it puts the mainsheet on even a lower angle running through the cockpit.
Well I would safely say it's not a standard rig sail. It could be a standard tall rig sail that the PO had made with a shorter luff to raise the boom. Easily done with your sliding goose neck.
