This is a bit of a lazy question, I should just drive out to the boat and look...
But... what is the likely CDI furler model on my 1995 C250 WB? I Googled around for a manual but it looks like there are several versions for the Flexible Furler.
Most of the early WB models shipped with FF2. WK models typically had FF4.
You can find manuals online and look at the pics.
I'd be careful about removing that "downhaul" - it may actually be a messenger line that is required to raise your jib. (I can't make it out from the picture.) Check the instruction manual for details on the procedure.
Neither model comes with ball bearings. It rotates on a HDPE slider bearing. An optional torlon ball bearing upgrade kit is available for the FF4/6 models. I have it, but it's not really needed. FF2 does not have enough friction to need ball bearings.
I second the messanger line. i made that mistake my first time also, not realizing the repercussions of disconnecting the line and then hauling the halyard up the track.
in my defense, my halyard was jammed and broken. i would suggest that you get another halyard for the track. mine had the holder style rope with the little slider car. the new ones are better rope with a ferrel.
and grease the little wheel in the swivel at the top. mine squeeks and it's very loud
i also contemplated getting the ball bearing upgrade for mine, but couldn't justify the cost. even with a little wind the jib usually unrolls pretty fast, and hauling it in doesn't seem bind much on the bearing
I would check the care instructions before lubricating, to see what CDI recommends. As with winches, the wrong lube could gum things up, collect grime and salt, etc. My furler had torlon bearings--the instructions were to never lube them with anything--just douse with fresh water. Of course, the non-ball-bearing CDI could be different.
Manual says not to lubricate, just wash it out with fresh water as you said Dave.
I read the manual, stared at the furler for a minute, and it turns out to be super simple.
You pull pin C, drum B slides up on the luff and you can see the large torlon bearing in the base. The whole thing was one big dirty mess. Looked like fine dirt. I sprayed it all out with the garden hose, slid the drum back down, pinned it. 100% difference in the feel and friction on the drum.
Our 2008 250wk (mkII) came with the FF2 to manage the 135% Genoa. I think it was WAY too small for that task. I upgraded to the FF4, and it worked MUCH better.
2008 C-250wk #973 Bluebell Whiskeytown Lake, California (formerly of Lake Tahoe)
