I am curious about how many of you trailer with the outboard and the rudder hung in place on the transom ? I have towed mine 3 times now but never with either hung. But in all 3 moves, I was not on my way to launch. I have a 9.9 4 stroke out board and I am concerned about the weight stressing the transom. Your views will as always be appreciated. Thanks again.
surely you have experienced more swell while docked or sailing with the engine in the up position and nearly out of the water. I've only lunch moved mine a couple times, botherwise with everything attached.
No, I have not yet experienced swell and waves as I have not yet had my boat in the water. But I can tell you as a professional truck driver that pot holes and rough roads in general are going to be more stressful in towing than swell or waves. At least this is my opinion. But everyone here has more experience than I and that is why I ask. Thanks again for your help. Good sailing all.
I didn't trailer my C-25, but I've trailered boats. None of their trailers had limousine suspensions! With the outboard on a bracket on a C-25, I would have either removed the motor or tied it to a stern cleat and/or stern rail base with the bracket raised, to absorb some of the impact forces from road imperfections. I had a large Starboard plate under the bracket mounting surfaces that would have helped protect the transom, but I would have removed the motor for anything more than a short, slow-speed trip on a familiar route. The rudder would have come off for its own protection--that's easy.
I trailer 2000 miles a year with the rudder and engine on and have for 7-8 years. I add a line from the mount to the stern rail to take part of the load. I also secure my kick-up rudder partially up. And you are correct that a swell doesn't come close to the load from hitting a pothole at 60.
Dave B. aboard Pearl 1982 TR/SK/Trad. #3399 Lake Erie/Florida Panhandle
Just wanted to make sure I wasn't being concerned without reason. I will never be trailering more than about 50 miles when the time comes but she's an old girl and I don't want to stress anything that I don't have to. Thanks again.
we live in calf. and never travel with the 9.8 motor and rudder on. backup the truck with tailgate down to stern of sailboat and remove both and place in truck bed with moving pads around them, motor chained to truck. been doing this with all our trailer sailboats for past 30 years. the roads in CA are the worst!
Lynn Buchanan 1988 C25 SR/WK #5777 Sailynn Nevada City, CA
I've never seen or heard of a C25 transom being damaged by carrying the motor on it while on the road, but I suppose it's possible. The first year that I owned my FK C25, I failed to check the motor clamps, or to attach a safety line to the motor, and the motor fell off, but the transom wasn't damaged. I never made those mistakes again and never had a re-occurrance.
I usually left the motor on, and left the rudder on for short distances, but removed the rudder for long distances. On a wing or SK, the boat sits lower, and it's easier to remove and re-install the motor, but on a fin keel, the boat is very high, and it's very difficult to remove and re-install the motor singlehandedly. Moreover, most of the weight of an outboard motor is in the power head, and that makes it top-heavy when it is above your head and you are trying to lift it off the mount.
My suggestion is that you use whatever procedure that works for your particular boat and your needs. If you have a beefy young helper, then removing and re-installing it makes sense. If not, then leave it on the mount and tilted, with a safety line, and it's doubtful that there'll be any harm.
100'ish pounds beyond the stern probably takes 100'ish pounds off the ball. If it impacts it that much you're probably at the absolute minimum tongue weight for your rig.
It does reduce the tongue weight enough to cause sway. I just wanted to throw that out there so the first time the OP pulls the boat he could watch for it.
This would be easy to fix by sliding the boat forward on the trailer a couple inches but I no longer have to trailer the boat.
Great advice as always. I will not be trailering often and am currently on a waiting list for a slip. Once she's in her slip I will be selling the trailer, problem solved. I just don't want any undue wear or damage in the meantime. Again my thanks.
THe way you said it originally indicated that adding the outboard increased tongue weight. I'm merely pointing out the effect is the opposite.
You both agree. Insufficient tongue weight induces sway. But if the outboard causes that, the tongue weight might have been a little low to begin with. The lever-arm aft of the axles is relatively short compared to that forward to the tongue--110 lbs. back there will translate to much less than that at the hitch.
. . . never travel with the 9.8 motor and rudder on. backup the truck with tailgate down to stern of sailboat and remove both and place in truck bed . . .
