I have a Nissan 9.8 and had an idle problem. I cleaned the carb and adjusted the screw near the rear of the carb. Now it will ladle but when I open the throttle it bogs down and stops.
Ncbrew
1998 Catalina 250WK Ravaging Albemarle Sound,NC
I spent most of my money on boats and beer, the rest I just wasted.
I would check the main jet and make sure its flowing freely.
If you give it throttle slowly, does it die or will it eventually gain rpm? I had this issue with my yamaha OB. It would bog, but didn't die. I leaned up the idle mixture, and opened it up a little more on idle. On mine there are two sets of low speed jets. One is fixed, and the other is adjustable with the idle mixture jet. I opened up the throttle enough to pick up fuel from the fixed jet and then turned down the idle mixture to get my idle right.
One other thought is that you may have a vacuum leak between the carb and the manifold. Spray a little carb cleaner around that connection. If the idle jumps you know you're sucking air somewhere.
Ya, I was going to mention an air leak--it could be anywhere from the tank to the carb--particularly either of the two connectors. (Of course, another cause of those symptoms can be a closed tank vent, but I wouldn't want to suggest something that obvious... )
I don't know about your motor, but there is commonly an acceleration pump that shoots a bit of fuel into the throat when you open the throttle. Usually its a little piston that the throttle linkage pushes down on the side of the carb. I just tore down and cleaned my Merc carb and discovered a little debris that prevented the pump lever from returning and filling. Also, by clean. do you mean the you disassembled the carb and cleaned all jets and orifices with carb cleaner?
Dave B. aboard Pearl 1982 TR/SK/Trad. #3399 Lake Erie/Florida Panhandle
Ncbrew
Found the problem "water in the gas"
Here is how I fixed the water in the gas problem.
It's pretty clever and seems to work well. I had visible water running around in one of my tanks, I poured the contents of the tank into another tank, and the funnel slowly filled up with nasty water. As it filled, I went out and poured the residue into the cracks in my driveway.
Now I use it all the time for putting fuel into any of my containers, plus the boat has it's own Racor fuel/water separator should any get past the funnel thingy.
David C-250 Mainsheet Editor
quote:Water and debris will collect in the sump, the area below the filter. Pour sump contents into separate approved container and treat as hazardous waste.
So Dave, The cracks in the driveway are an approved hazardous waste dump?
A Racor separator is pretty much a necessary insurance policy now--especially for anyone who buys their gas at a marina. Gas cycles through their tanks much more slowly than at typical car gas stations and sometimes sits totally stagnant through the whole off-season, inviting phase separation of acidic water, and little outboard carburetors are much more sensitive to water than car fuel injectors.
As a guy who was driven to a Torqeedo by 4 stoke engines, I really believe everyone should just carry a new carburetor with them and take their time rebuilding the alternate unit... just keep cycling them. It is so easy to change one out.
...I really believe everyone should just carry a new carburetor with them and take their time rebuilding the alternate unit... just keep cycling them. It is so easy to change one out.
...even when you're trying to enter a marina with a cross-wind and a current. It just takes a Phillips, a 3/16" socket, a flat blade to release the carb from the gasket, and 5-6 minutes with nobody yelling at you to not run into their boats...
Hope that works... That's a lot of "lift" from the tank to the Racor. Is that another filter just above the outboard?
My layout was different, with the cockpit fuel locker on port and the outboard on starboard, but here's where I put my Racor...
The lift is not a problem at this time. (fuel pump is working fine). I like your setup and I may move mine. That is a paper filter and I may remove it.
