 Cabin Table
pearson39b
Initially Posted - 11/04/2015 :  14:39:04  Show Profile
Starting to put together my project list for rehabbing my 78 model, and one essential item is rebuilding the cabin table for this L-shaped dinette configuration. I'm having a hard time believing Catalina delivered this boat with the current formica covered, particle-board table, but that's what's currently falling apart and needing replacement. Also having a hard time finding 1" marine plywood, which would be my first choice for replacement material, so I'm wondering if anyone here has taken on this project before and has any suggestions regarding materials and techniques. Not in a huge hurry, but would like to start getting my ducks in a row.
Anyone?
Sailor Jerry
C-25 "Sea Song"
1978, SK, Std.
Pepin, WI
Edited by - pearson39b on 11/14/2015 09:51:05
dasreboot
Response Posted - 11/05/2015 :  05:16:09  Show Profile  Visit dasreboot's Homepage
you could glue together 2 1/2 inch pieces. would be just as strong. I was thinking about doing a foam core table with 1/4 or 1/8 plywood glued to either side of the core.
Todd Lewis
Eowyn 87 TR/WK C25 #5656
ARWEN 84 TR/SK C25 #4031
www.mainsailsailingschool.com
Response Posted - 11/05/2015 :  09:07:17  Show Profile
Jerry, Since it's an inside table it really doesn't have to be "Marine" grade wood unless you plan on putting it outside. If you are going with plywood I would think an exterior grade would be fine.
dasreboot
Response Posted - 11/05/2015 :  11:27:02  Show Profile  Visit dasreboot's Homepage
foam core table for RV
http://www.popupexplorer.com/forum/index.php?topic=77322.0
Todd Lewis
Response Posted - 11/06/2015 :  08:43:18  Show Profile
From our Tech Tips--Knot Yet's dinette table made of teak strips...
Response Posted - 11/06/2015 :  19:28:36  Show Profile
Teak or birch veneer plywood stained to look like teak -- with teak trim should do just fine. I have been thinking about redoing mine with teak veneer plywood to make it lighter and better looking than than the original formica
Peter Bigelow
C-25 TR/FK #2092 Limerick
Rowayton, Ct
Buzz Maring
Response Posted - 11/08/2015 :  08:01:53  Show Profile
Hi Jerry,
I don't know how bad your table is. If it isn't completely falling apart you might consider taking the formica laminate off and replacing it with teak veneer (as suggested above).
I also have an L-dinnette, and while my table wasn't falling apart, the PO had spilled something on it, and it looked pretty nasty. The table top was still sturdy, so I chose to trim the edges off and build a new top using the old table as a base. That made it pretty sturdy, and I didn't have to worry about remounting the top of the pedestal to the table bottom.
I bought a bunch of teak printer stands on eBay. No one else wanted them, so I got them for a song. They were made of solid teak, and I got the wood MUCH cheaper than I would have if I'd bought teak by the board foot. I have used that wood for several projects, and I still have a little bit. 'Turned out to be quite a bargain.
Anyway, I've lost most of my photos due to several hard drive crashes over the years. I did find this photo that will give you an idea of how it looks. My table has the same dimensions as the old table, so I am still able to lower it and use that area for a sleeping berth ...
Whether you decide to build a new table from plywood (or some other material), cover it with veneer, or build a new table on top of the old one (as I did), you might consider adding some wood strips to the edges to act as fiddle rails. They'll give it a nice finished look by hiding the edges, and they'll help keep things from rolling off the table when heeled. I have fiddles on the edges that I made from a curved part of the teak printer stands I bought ... they're kinda' hard to see in my photo.
Whatever you decide to do, keep us posted on your progress, and good luck!
Buzz Maring
~~Freya~~
C-25 SK/SR #68
Lake Dallas, TX
pearson39b
Response Posted - 11/08/2015 :  13:47:45  Show Profile
Kinda sorry I asked this queston, cause now I'm not going to be happy with just doing a quick and easy fix! These tables really ramp up the quality level....
I do have to build a new base, Buzz. The particle board is falling apart, and besides - I hate the stuff in this application - too heavy and structurally fragile. I'm hoping I can get the old fiddle rails off and re-use the, and I like your idea of putting a finish veneery over a marine plywood base. Will try to photo document the project once I get started...
Sailor Jerry
C-25 "Sea Song"
1978, SK, Std.
Pepin, WI
pearson39b
Response Posted - 11/08/2015 :  13:53:28  Show Profile
Sorry, should have credited Peter with the veneer idea.
I also followed up Todd's link on the foam core idea, but not sure I've got the time or skills to pull that one off - attractive though it is...
Sailor Jerry
C-25 "Sea Song"
1978, SK, Std.
Pepin, WI
Bladeswell
Response Posted - 11/09/2015 :  07:10:01  Show Profile  Visit Bladeswell's Homepage
Hello Pearson,
I have a 79 "L" shape Dinette C25. Mine is teak. Good luck with your restoration. Bladeswell.
pearson39b
Response Posted - 11/14/2015 :  10:10:07  Show Profile
I wanted to salvage the trim around the edge of this table and simply replace the particle board, but I'm now leaning toward rebuilding the whole unit and putting new trim on a new base of exterior plywood with a teak veneer glued on top of the ply.
Really like the looks of Dave Bristle's trim, and I'm wondering where you got it, Dave?
Sailor Jerry
C-25 "Sea Song"
1978, SK, Std.
Pepin, WI
Buzz Maring
Response Posted - 11/14/2015 :  11:12:27  Show Profile
Hi Jerry,
That isn't Dave's table ... he got that photo from the archives ... it was someone else's project.
You might be able find something here: http://www.plasteak.com/, but it won't be cheap.
You might just try to Google "teak trim" or "teak accessories," or you could even look for a boat salvage company that might have something you could use. You could get lucky and find a ready-made table that you could use as-is.
BTW, from the looks of your table, that isn't the stock table that came with the boat.
Buzz Maring
~~Freya~~
C-25 SK/SR #68
Lake Dallas, TX
Response Posted - 11/14/2015 :  12:50:23  Show Profile
Looks like standard teak trim or molding. Do a search for it and you will come up with multiple suppliers.
Response Posted - 11/14/2015 :  20:10:15  Show Profile
Yup--Knot Yet is knot my boat. That's a project from our Tech Tips section (on the menu at left). I suspect the moldings, including the radius corners, are standard pieces like these at Defender, which are certainly available elsewhere.
Edited by - Stinkpotter on 11/16/2015 08:06:34
pearson39b
Response Posted - 11/16/2015 :  21:55:00  Show Profile
Good link, Dave. Thanks.....
Sailor Jerry
C-25 "Sea Song"
1978, SK, Std.
Pepin, WI
sdpinaz
Response Posted - 11/20/2015 :  20:24:52  Show Profile
Jerry,
I will be in Santa B in January. If you are around then, I would be happy to help you make a table. We have a full woodworking capability, table saw, router, planer, etc....
Cheers,
Scott
Scott
'88 WK/SR #5727
pearson39b
Response Posted - 11/27/2015 :  10:34:23  Show Profile
Scott,
Thanks for the generous offer. I think I may have found a solution back here in Wisconsin, but if that doesn't work out, I may take you up on it.
At any rate, I'll be back in Ventura by January, so give me a call if you want to get together when you come out. Really enjoyed our sailing last year.
Regards,
Sailor Jerry
C-25 "Sea Song"
1978, SK, Std.
Pepin, WI
Tomas Kruska
Czech Republic
Response Posted - 11/28/2015 :  05:42:07  Show Profile  Visit Tomas Kruska's Homepage
Originally posted by Buzz Maring
Wow, this is very nice interior. Don't you wanna share more photos please? Thumb up.
Dalpol Phobos 21, 2013, Sole Mio, hull #27, current adventures - We sail Phobos 21
PO of Catalina C25, 1978, High Anxiety, hull #701, SR, FK, L-dinette, inboard diesel Volvo Penta MD2010C w/saildrive - more info
Response Posted - 11/28/2015 :  07:56:57  Show Profile
Are these and more examples out on the forum photo pages?
Buzz Maring
Response Posted - 11/28/2015 :  08:15:29  Show Profile
The photo Tomas asked about is mine from Freya. I'll dig up some others and post them later. After several hard drive crashes I'm having a hard time finding them
Buzz Maring
~~Freya~~
C-25 SK/SR #68
Lake Dallas, TX
Buzz Maring
Response Posted - 11/29/2015 :  17:00:38  Show Profile
Thank you, Tomas, for the compliment! I have found a few more photos, so I'll go counterclockwise around the salon to show a few other mods I've made.
I should start by saying that I have a Norwegian heritage ... my grandparents immigrated from Norway at the end of the 19th century. In Norway everyone owns or rents a cabin in the mountains to get away from it all, entertain friends and family, etc., and the farther away from civilization, the better. Freya is my "mountain cabin." Norwegians like to put their own touches on their cabins with handmade items, so that's what I've tried to do.
Here is another shot of the table I made from the teak printer stands ...
This is a coffee mug holder I made ... it is mounted above the galley ...
Here is a shot of the galley ...
I made a cabinet to store my galley ware ... you can just make it out behind my big sister. I also installed a small basic navigation station next to the companionway, and below that in the quarterberth you can see a teak cockpit grate that I made into a table for the cockpit ...
Here is what the cabinet looks like closed ...
Here it is open ...
I also installed a portlight underneath the starboard cockpit seat that lets light into the quarterberth. This last photo is a little cluttered, but it shows how much more light there is now ...
OK, that's it. I sure got a lot of mileage out of those teak printer stands I found on eBay ... 'one of the best bargains I've ever found! I have some teak left and a few more projects in mind, but I have to keep Freya on the hard for now due to financial concerns ... but ... things will get better.
Buzz Maring
~~Freya~~
C-25 SK/SR #68
Lake Dallas, TX
Response Posted - 11/29/2015 :  17:13:34  Show Profile
Wow Buzz! That has to be the most beautifully fitted out C25 ever!
Buzz Maring
Response Posted - 11/29/2015 :  18:09:54  Show Profile
Wow
Thanks, Steve! That means a lot, especially coming from you ... you've been a valuable member of the Catalina family and of this Association for a loooong time.
Buzz Maring
~~Freya~~
C-25 SK/SR #68
Lake Dallas, TX
WesAllen
Response Posted - 11/29/2015 :  19:44:35  Show Profile
WOW Buzz. Very nicely done. Umm, do you mind if we copy a few of you Ideas like the wine glass holder, and a few other things.
Wes
Wesley Allen
"Breaking Wind"
1982 C-25 SR/TR/SK #2773
Hemlock, MI
Tomas Kruska
Czech Republic
Response Posted - 11/30/2015 :  06:48:32  Show Profile  Visit Tomas Kruska's Homepage
Thanks Buzz! You have pimped up your boat very nicely. It's my cup of tea.
That's why I love this, so called boat po*n, you can find very interesting ideas.
Response Posted - 11/30/2015 :  08:00:41  Show Profile
Very nice, I guess working with wood is no stranger to you. I especially like the use of Carabiners to hang the coffee mugs on.
