Hello All, I'm about to remove my To-hulls and gate valves. I will be relocating the new thru hulls and will need to fill the existing holes.my question is, is it OK to fill with 5200 or should I use thichened epoxy..? Thanks again. Bladeswell
Neither. A hole below the waterline should be glassed in with fiberglass mat and unthickened resin. I recall West System has good manuals on how to do it right, tapering the outside of the hole and using overlapping layers, as do various books on fiberglass boat repair by the likes of Don Casey. A plug of either caulk or epoxy is liable to pop out, and you know the rest.
You've probably thought about it, but, unless there is a compelling reason to relocate the holes, it would be much easier to put new valves in the same holes and be done with it.
...it would be much easier to put new valves in the same holes and be done with it.
Ditto.
Yes, there is a very real reason to reloacte the holes. In my boat, Catalina decided to mount the Too-hulls straight up and down rather than 90 degrees from the hull. If I tried to install the mushroom marelon thru-hull like that, it could not seat flush with the outside of the hull. Nore could the mounting nut seat flush inside the hull. The other reason is that I want the head sink drain seacock located directly under the sink rather than under the starboard settee just aft of the head compartment bulkhead. Even if I wanted to reinstall them in the same place, I would need to fill and redrill. Thanks again all. good sailing.
Most descriptions here for that job have included grinding away the epoxy "mushroom" on the inside of the hull, to eliminate the problem I suspect you're describing. Here's an excellent description from our Tech Tips section. (Thanks Todd!)
I was at the boat yesterday and after clearing out the stuff that was in the cabinet under the head sink I discovered that there is a "level" floor there. So I will not be able to move the sink drain there after all. But I bet you all knew that already. So it will be staying in the same compartment it was in to begin with. Seems I discover something new about the boat each time I open up a new compartment. I will say that in my boat's case the too-hulls and gate valves were tough to remove. I have the gate valves off but still have to figure out how to get the bronze pipe nipples out of the hull. Thanks again for your patients and noob tolerance. Be safe all.
If you check out the archive section and use various keywords you should see several threads and more than a few descriptions of owners who have replaced, modified and /or relocated all types of through hole fittings on our boats -- take advantage of our collective wisdom as to what to -- and what not to do -- as chronicled in the archives.
Peter Bigelow C-25 TR/FK #2092 Limerick Rowayton, Ct Port Captain: Rowayton/Norwalk/Darien CT
I'll re-open this topic with a link to a new Sail magazine article on patching over unwanted thru-hull holes in the hull in case someone searches on this subject:
I'll offer an opinion that if this guy could have accessed the area inside of the hull, he should (and probably would) have done some of the same process there. Presumably, he could simply overlay the inside surface with a couple of layers since there's probably no reason to make it fair or smooth. The objective is simply to reinforce against any tendency for the patch to break away toward the outside.
