 Show me your mast gate!
kiko
Initially Posted - 03/02/2015 :  22:03:13  Show Profile  Visit kiko's Homepage
So I've looked at Catalina direct's version and some others on the net. Anyone have a mast gate that worked well for them?
Thanks in advance Team!
1979 C-25 SR/SK/Dinette
14' Hobie Cat
Sunfish
Edited by - kiko on 03/02/2015 22:04:06
WesAllen
Response Posted - 03/03/2015 :  00:52:56  Show Profile
I purchased the mast gate from CD and it was very easy to install. Need only drill screw holes (it came with a tap for the threads) and file the ends to fit the opening in the mast. Works great.
Wesley Allen
"Breaking Wind"
1982 C-25 SR/TR/SK #2773
Hemlock, MI
Response Posted - 03/03/2015 :  06:44:22  Show Profile
Ditto.. CD .
Others suggested you put Locktight on the SS screws to act as a barrier between the screws and the mast to prevent galvanic corrosion..
I need to redo mine.. ( add that to the list )
Kim Luckner
Response Posted - 03/03/2015 :  07:24:16  Show Profile
I used an "L" shaped piece of aluminum trim for steps as the starting point, should be available at hardware. It was suggested by someone on this forum originally, but I couldn't find the reference using the search tool. Hack saw and file will do all the shaping. Then a few holes along the length to attach. The short leg of the "L" is fairly short, slightly less than 1/8 inch, and needs to be a smooth transition from mast to gate. After some fusing it's worked well for several years, put it on in the spring and take it off in the fall.
Seeadler
'79 C25 SR/FK #1432
Mentor Lagoons
DavidBuoy
Response Posted - 03/03/2015 :  08:41:41  Show Profile
I've got the CD kit as well. Haven't been able to install it yet as I'm not really keen on climbing around the boat in the water with a thick coating of ice and snow on it. Will post some photos when I get it installed in the next couple weeks. Actually, this weekend looks like a good candidate, will update.
Captain Rob & Admiral Alyson
Response Posted - 03/23/2015 :  05:51:00  Show Profile
I'm sorry.. it was so bright out there I could not see where the camera was focused..
Response Posted - 03/23/2015 :  06:08:13  Show Profile
The mast gates are different from boat to boat. I guess it depended on who at Catalina was cutting them on any given day. You can see the difference between Ray's and mine. I only have one side cut and is much smaller so the CD kit will have to be shaped and filed to fit your gate.
Response Posted - 03/23/2015 :  06:11:20  Show Profile
There are 3-4 tech tips that show how to make your own mast gates. Probably the easiest was submitted by Bill Holcomb. Here's the link. http://catalina-capri-25s.org/tech/tech25/snkslot.asp
Response Posted - 03/23/2015 :  06:16:01  Show Profile
Ha.. and neither one of us can focus
Response Posted - 03/23/2015 :  06:24:48  Show Profile
Yea, keep forgetting the Micro setting..
Response Posted - 03/23/2015 :  11:15:48  Show Profile
I had mast gates on "TSU" for years (bought them from the original maker). They worked wonderfully and were especially useful when reefing.
Chief Measurer C25-250 2008
San Antonio, Texas
kiko
Response Posted - 03/23/2015 :  12:11:05  Show Profile  Visit kiko's Homepage
Thanks for the pics and help to everyone that chimed in, very helpful!
I always thought that a mast gate would allow you to fit the slugs in, using a spring or something that then closed up afterwards. Then to take a slug out, you would press in the mast gate to remove. So far it looks like this mast gate is something I would have to take apart (unscrew) every time I trailered the boat somewhere else so I could take the main off.
Anyone seen/heard of something like what I am detailing?
14' Hobie Cat
Sunfish
Response Posted - 03/23/2015 :  13:01:50  Show Profile  Visit britinusa's Homepage
Frank, on the C250, the mast has the same cutout to allow insert and extraction of the sail slugs.
But instead of a mast gate, it has a screw about 1.5" long 1/4" dia with a head about 1" in diameter.
The 'gate screw' is threaded into a threaded hole in the mast that is on the inside of the mast sail track.
The mainsail has a jack line for the lowest slug which allows the sail to be reefed while the slug is still above the gate screw.
Here's a good page that describes the principle
Joint Decision. (Sold)
PO C250WB 2005 Sail # 841.
Moved up to C34 Eximius
Updated August 2015
Response Posted - 03/24/2015 :  04:48:23  Show Profile
<< So far it looks like this mast gate is something I would have to take apart (unscrew) every time >>
And if you drop a screw it bounces twice and goes kerplunk into the water.. So ya gotta get extra screws...
Arlington
Response Posted - 04/06/2015 :  20:49:53  Show Profile
Frank, after loosing one of my mast gates at the dock, through experimentation I found If I removed just one of the screws on each side of the gate. The gate would be still be secured to the mast by the remaining loosened screw. Therefore it could not jump into the drink.
God created the Seas as a blessing to Sailors.
Doug, Jenny & First Mate Taylor, Arlington TX
No. 5842 "Promise"
1989 C25, TR/WK, Inboard Diesel,
1995 Stratos 278, 115 HP Evinrude
1978 14' Dolphin Sr.
Edited by - Arlington on 04/06/2015 20:54:18
