The rubber ring at the top which the line 'cleats' into is falling apart on our winches (the rubber is disintegrating, I'm assuming it's the original winch). I haven't been able to find anything like it anywhere.
Specifically I'd like to just replace the rubber ring at the top. Any ideas on where I might find this replacement? I looked on CD's website, but didn't see anything there.
I added Winchers to my C25. They would be better called "cleaters". They will easily hold a sheet without cleating it off.
There are two problems with Winchers.
1) To get them to "self-tail" you need to load line on the winch. It does work, but easing the sheet is a little more difficult because of the number of wraps needed to "self-tail".
Photo of self-tailing:
Photo of "cleating":
2) In my case, I had 3/8" sheets. They were too large for the "cleating" part and I ended up changing the sheets out with 5/16" line. The 5/16" line would grab in the Wincher but of course required more turns on the winch (see photo above).
They are a compromise at best. I'm not sure I would add them for sheets again. Maybe on a halyard winch.......?
<font face="Comic Sans MS"><font size="3"><font color="navy">The rubber rings around the the top of your winches are a fake self tailing cleat. They never worked that good but were fine for casual cruising. IMO They were never necessary, a cleat or a cam just past the winch is more than sufficient. Learning to sheet in as you tack will make trimming the jib easier and faster without the need for a self tailing winch.
A suggestion is to cut a hole out of the bottom of a box and place it over the winch before you start to open it up. It will catch the pieces that <u>WILL</u> go flying as you disassemble it...
IMO forget the rubber rings, learn to sheet in as you are coming about and service your winches at any sign they are hanging up.
</font id="navy"></font id="size3"></font id="Comic Sans MS">
