While we have perfected a gin pole for our tall rig . . .
. . . we still haven't figured out an adjustable height mast crutch. Because the tall rig is 2' longer and has a thicker extrusion, it takes quite a bit of effort to raise. We still have to "walk" the mast up quite a ways before the 4:1 block and tackle can take over.
Has anyone here created a mast crutch that can be extended (upwards) while the mast is sitting on the crutch?
on our C250WB our mast crutch is two part. The outer tube is attached to the boat by a spare pair gudgeons, the inner tube can be raised about 2.5/3 feet. There are matching holes in the top of the outer tube and the inner tube.
Once all of the lines are checked with the mast sitting in the crutch in the lower position and the mast moved aft and bolted to the mast base plate. Then I pull the pin lift the inner crutch tube and the mast upward until the holes line up, put the pin back and we're ready to take the strain with the winch strap.
I use a setup similar to britinusa, and it's workable for the TR.
Your gin pole design looks quite nice: any chance you could post some drawings and/or some additional pics, along with a description?
Hi Paul and thanks. We are trying to come up with something where once we roll the mast back and run a pin through the tabernacle, the crutch would be raised using some mechanism . . . perhaps like a crank on a trailer jack. We're also looking to have the crutch raise vertically by about 6'. Yeah I know, that's a lot.
The ultimate goal is for two people to be able to raise the mast.
Thanks for the complement Michael. I chuckled when I saw word "drawings". Briefly, I created mock-ups using corrugated cardboard and a hot glue gun. Once I got that right I scribbled down the dimensions on a scrap piece of paper and gave them to my dock neighbor - who owns a machine shop - and also a C25.
I will post some pictures of the "shoe" with a tape measure showing the different dimensions - after we finish commissioning our boat for the 2014 season!
Another challenge the tall rig presents in conjunction with the crutch is the spreaders are just aft of the gudgeons when the mast is horizontal. Something else to keep from getting tangled.
Mine is made of this material with only two sliding sections.
That is a great piece of work. The forestay is a good pulling cable to use. The pole could be braced side to side which would help steady mast. Maybe lines attached also with forestay and lead back to points even with pivot of mast step. More power to lift could be made with a snatch block at the attach place of the forestay and the end of the pole. Extending the mast crutch loaded with the midpoint of the mast resting on it is a challenge. If the mast crutch is set at the height where it is still a comfortable lift to place the end of the top of the mast before rolling it back to secure the mast step should be ok. A safety line ready to secure the mast when verticle would aid changing over the forestay from the winch line and pole to the deck fitting, the jib halyard is a choice. The ideas here are just suggestions with safety in mind. The snatch block would almost double the effort which could make raising the mast crutch re considered. Do it safe.
