For those who have a cabin heater - what are you using?
Not sure what others do but this time of the year down here in the South I just turn off the A/C and take out the crib boards and let the heat in when I get too cold!
I use an electric heater with a ceramic core. Works really well. Even on the coldest nights I could keep the cabin around 80 if I wanted to.
I use a small electric when on shore power and a Mr. Heater propane when not on shore power. Typically I do not light the propane heater until I wake up in the morning. It heats the boat up very quick. Been on boat with temperatures in the 30's in the AM.
Used Princess 2 burner with flower pot, electic heater with shore power then found this in used boat store. Kerosene which I replaced with Colman catalic and it works. Lots of polishing and kept monoxide detector on board first cruise. Best heat for Northwest and it doesn't make moisture. Daughter said why didn't you do this long time ago. Price was right.
<ul><li>Low cost, since I use it so infrequently</li><li>Three user-selectable heat levels (I think it's 600, 900, and 1500 watt) allows me to use the minimum heat needed</li><li>High air volume keeps the surface temperature low. Its plastic case would melt if it didn't do this.</li><li>It has a thermostat</li><li>Dry heat</li></ul>
Wife gave me this one for Christmas a few years ago when we still had the C25. Great cabin heater but does require shore power. It has an "anti-freeze" setting that is very useful, turns the heater on when the temp drops to 38 degrees. Used it in my C22 over the winter to keep any rain water leaking in from freezing. A bit pricey, but good to buy when on sale. http://www.westmarine.com/buy/west-marine--portable-cabin-heater--7867500
Jim, thanks for posting. I have always been a fan of Force 10. Apparently these are no longer manufactured . . . but there are used ones to be had. From what you can tell, are there many parts that would eventually wear out and need to be replaced? Are those parts generic enough that they could be sourced at most hardware stores?
The Coleman small catalic fit up inside with out modification and did have to add a strap of stainless metal. Didn't do much metal work and it is secure. Tested by installing the CO2 alarm. Checked the moisture on the windows which was much less even on the rainey days we had before.
