I have been re-doing and re-rigging all the lines on my boat a little at a time. Yesterday I went to install a triple deck organizer to run the cunningham to the cockpit. I was unable to get the triple organizer to mount where the double was. Catalina Direct indicated that there was a plate in the deck that the mounting screws were threaded into. Not so. They are thru bolted. If I installed it the inner line would run under the pop top front corner. A friend and I worked on several angles/ways to get it mounted but the combination of the location of the thru bolts and the pop top was always an issue. Hopefully CD will let me return the triple.
Frank I how do you get the blocks at the base of the mast to be at different heights so the are organized like yours. hard to see from the picture. How do you know which to buy. I know you liked the Harken Quad but what did your use for the line/sheet clutches
Don't return the triple, they work great. And don't bother trying to stagger the mast blocks, it all works out. Lay out your organizer with all the lines in the blocks, organizers and rope clutches. Get some tension on the lines so you can see the angles. Find the best spot on the deck and turn the organizer so the lines exit at equal angles. It all makes sense once you lay it out. Those are Harken organizers and Garhauer blocks. You will probably find as I did eventually that a double on each side is plenty. Go simple and go sailing!
I suspect the position and bolts for the doubles won't be ideal for the triples. To run three lines back past the pop-top, the triple organizer might have to be angled more toward fore-and aft, so the lines run closer together going aft. I'd forget about the current bolt holes, drill what you need, and fill what you don't.
The stacked quads are also good--Frank's and Craig's blocks are shackled to the mast base plate as mine were, and the lead angle to the upper sheaves might be better than to the lowers, but they all should work fine. I had triples, and also a pop-top.
Catalina Direct will let me return the triple. I did not want to have holes in the deck that were not used to change the angle to make it work. I have doubles I can stack and probably will. I did not do it originally because I thought I may trip over it due to the additional height. My problem is I crew on an older C22, without a pop top, that has a johnson bar with all the lines running to it that make things so handy when racing. I need to back off thinking I need that convenience on mine. I do not race the 25-unless there is another sail boat out there.
