I'm swapping to rope halyards and I have the new CD spreader bracket kit. I've been looking at how I'm going to run everything inside the mast.
The CD kit has a compression sleeve for the lower bolt as well as a larger sleeve (1" Diameter) that goes between the spreader posts. The original setup didn't have the larger sleeve. I don't know if there is going to be enough room to get the ropes around all of that. In my mind, I can omit the larger sleeve and install the new brackets just like the old ones. Has anyone else run into this problem?
Yes there is room. Halyards should not be any larger than 3/8" and many use 1/4". The point of the spreader upgrade is to add strength, do not compromise that goal.
I took pains in passing three 5/16" and one 1/4" sized lines past the internal sleeve (main, jib, spinnaker, and topping lift). Each halyard, I formed a Ballantine coil and tied the working end to the 30' Harbor Freight fiberglass push rod. I made sure to align my threading for port starboard, forward aft, sheaves, landing the mainsail halyard on the Catalina Direct ball bearing upgraded sheave. A source of my pain was threading the mast head and steamer light wiring, of which has a foam chunk taped every 10" (eliminates wire slap). Patience and occupying 60' of the dock helps. Result is a free running, untangled, internal halyard.
