 All LED
RichardG
Initially Posted - 10/22/2018 :  12:34:59  Show Profile
I removed the last of all the incandescent bulbs from my boat Saturday.
So now 100% LED inside and out.
RichardG 81 FK/SR #2657
Terminal Island, CA
sethp001
Mainsheet C-25 Tech Editor
Response Posted - 10/22/2018 :  12:37:06  Show Profile
Woot! Looks great!
My boat is all LED too.
Seth
"Nomad" 1980 Prindle 16
Response Posted - 10/22/2018 :  14:22:29  Show Profile
That is a very beautiful thing. Dedicated red LEDs and green LEDs are perfect for navigation lights. In my case I have a single bulb with a filtered lens. In that case a white LED (color temperature 5600°K blue-white) does not display the same color spread as a white incandescent bulb (color temp 2800° yellow-white), so the green side appears bluish and does not provide 1nm visibility. I therefore did not replace the bow red green with a LED. Also, I’ve kept my steaming light as a cheapie incandescent because I only turn it on while it’s dark and the engine is running, charging the battery.
Everything else is LED.
Edited by - Voyager on 10/22/2018 14:24:56
Response Posted - 10/22/2018 :  15:58:59  Show Profile
Dr LED makes a LED with green and red LED's. Here was my slightly humorous thread about it from 2011:
http://www.catalina-capri-25s.org/forum/topic.asp?ARCHIVE=true&TOPIC_ID=22721
2005 Gemini 105Mc
PO 1987 C25 #5509 SR/SK
Tampa Bay
Response Posted - 10/22/2018 :  17:11:41  Show Profile
Nice! Where did you find those beauty's?
Response Posted - 10/23/2018 :  03:04:13  Show Profile  Visit OLarryR's Homepage
Nice improvement !!
Larry
RichardG
Response Posted - 10/23/2018 :  10:42:36  Show Profile
https://www.five-oceans.com/collections/led-technology/products/led-navigation-side-lights-bc-3840
Terminal Island, CA
RandyAmy
Response Posted - 10/23/2018 :  13:09:58  Show Profile
Hole pattern matched up to old fixtures?
Randy Clason
RichardG
Response Posted - 10/23/2018 :  14:20:06  Show Profile
Perfect fit for the holes. It's an all-in-one fixture. Instead of the regular screws that came with it, I used the old nuts and through-bolts that also hold the so-called 'covers' inside the anchor locker. I'm thinking of making new, lower profile covers, which will allow more room and make easier neatly packing 300' of 1/2" rode, 50' of chain plus anchor in the locker.
Terminal Island, CA
